Before you do J-pipe and Exhaust do PCD or HFPC first. Measurement inside
Will be showing exhaust gasket on head later.
Cliff notes:
Why do j-pipe and exhaust when your still limited by how much exhaust you can flow by the pre-cat. Stock pre-cat outlet is only 1.75in. Most j-pipe have a 2.25-2.5 inlet. So your limiting your flow. Most cat backs are 2.5in and I know some people are running custom 3in. So start with the PCD/HFPC and work your way down. To J-pipe and then exhaust. just my .02 cent
RV6 HFPC v3
outlet 2.14in
inlet 1.73in x 3.20in
updated with measurement of stock precat
Stock outlet 1.76in
inlet 1.47in x 3in
you can see with the gasket on that the precat tapers and gets narrower the more you go in. This blocks air flow
HFPC with gasket
HFPC weights 5 lbs
stock with heat shield is about 9lbs.
My o2 sensor after 110k
Cliff notes:
RV6 HFPC v3
outlet 2.14in
Stock outlet 1.76in
inlet 1.47in x 3in
HFPC with gasket
HFPC weights 5 lbs
I agree about the order since you will probably get a better bang for the buck with PCDs. However, exhaust flow is the sum of all restrictions so even freeing up a smaller restriction will give you gains or us turbo people would be screwed LOL.
thisaznboi88 (10-07-2013)
This is true but not always the easiest or viable means to do
i.e.) Time+cost to install if on your own.
Time,cost, and labor if someone else has to do it.
Smog is a problem, unlike regular cats that are easy to re-install
Unless someone can say for sure they passed smog with high-flow or no cats at all
I've read it can take a minimum of 5 hours to do both precats
the rear is the one that takes forever.. Since you have to take off the tower bar, and play tetris. If you don't live in a state that does emission it is well worth the time and effort.
took me about 1:30 to do the front with hand tools. The rear I will tell you how it goes next week. lol
mlody
12-04-2019 02:11 PM
ExcelerateRep
10-14-2015 08:20 AM
