Average clutch replacement labor on 07 Tl-s?
Old Apr 18, 2012 | 11:49 AM
dstah's Avatar
What's up acurazine. I'm wondering what kind of special tools are needed to tackle this DIY ? I've done b-series/ k-series clutch before but haven't done any Tls.. I've called a few shops and most quoted me 600-450$ labor if I bring my own parts ( 1 day to complete ) . Does this seem reasonable ? I have access to lifts/air tools but wouldn't want to risk messing up o_O
Anyone know good clutch kits ? Or websites to buy from?
Old Apr 18, 2012 | 11:52 AM
i bought my oem clutch kit from Acuraoemparts.com
or Oemacruraparts.com for $250
which ever one is Delray.
the factory clutch is made by LUK.
I had an independent shop tackle the job for $400
Old Apr 18, 2012 | 12:02 PM
dstah's Avatar
The factory oem clutch should hold up just fine ? Or should I get another heavy duty clutch
Old Apr 18, 2012 | 12:05 PM
the factory clutch can hold up to 350wheel horse power.
at 450hp, is when you need to start thinking of something else.
Ask Hi speed or Rodney from J&R.
with my mods, i'm only at about 270hp.
no slippage, and its fine.
Old Apr 18, 2012 | 12:21 PM
maharajamd's Avatar
Did you rock the stock fly, have it resurfaced, or replace it?
I was told by a Honda tech that no matter what to replace the flywheel because if you don't you may get some chatter. But obviously the fly is the most expensive part. More then the labor for the job really.
So if you don't have to purchase a flywheel this is like a sub $700 project.
Old Apr 18, 2012 | 12:22 PM
dstah's Avatar
Right now I'm around 275whp so the stock clutch should hold fine. Reason why I need a replacement clutch is it slips at high rpm 2nd to 3rd
Old Apr 18, 2012 | 12:23 PM
what are your mods?
Old Apr 18, 2012 | 12:24 PM
Correct. All in all i paid about $700 for this clutch job.
I didnt have to purchase a flywheel.
I'm not sure if the shop re-surfaced or not. I know you're not supposed to...
with that being said, I have no chatter.
Old Apr 18, 2012 | 12:34 PM
maharajamd's Avatar
Good to know man thanks.
The same Honda tech I mentioned will be doing mine, he said $50/hr for 6 hours plus parts. So hell that willl put me at like $600 for a new clutch!
Old Apr 18, 2012 | 03:36 PM
dstah's Avatar
I have j pipe. Pcd. Mdx spacer. Intake. Custom exhaust
Old Apr 18, 2012 | 03:39 PM
dstah's Avatar
Acura dealer I called said $400ish for the clutch kit.. Is the clutch on oemacuraparts.com the same for $240?
Old Apr 18, 2012 | 03:42 PM
maharajamd's Avatar
Should be. I just looked myself the other day.
Old Apr 18, 2012 | 03:45 PM
Yes, as mentioned above....the OEM CLUTCH KIT IS MADE BY LUK.
you can price match your dealers with the online dealers.
it should be about $250
Ive seen in other threads where people get the same OEM clutch kit for cheaper! on ebay.
Old Apr 18, 2012 | 07:20 PM
dstah's Avatar
Hmm.. Still iffy about doing this myself but wouldn't want to deal with the headache.. I'll probably let one of my friends uncle who owns a mechanic shop tackle this for $450. So $450 + the clutch +$250 = $700 total.. Reading the fourms last night scared the shit out of me cause I read somewhere it would be $2000ish
Old Apr 18, 2012 | 07:23 PM
maharajamd's Avatar
I think $450 is a good deal. As long as he is trustworthy.
I think the dealership would charge you $100/hr for 10, 12 hours for this job?? $1000 labor, $250 clutch, $500 fly? $1750 right there....
Old Apr 19, 2012 | 08:40 AM
Xiomaro's Avatar
1st 3g Turbo TL-S
go oem or if you want a little more grab get the p2r clutch disc from j and r
Old Apr 19, 2012 | 08:58 AM
bouncer07's Avatar
$80 times 6hr job = $480 (not including shop tool fees)
$90 times 6hr job = $540 (not including shop tool fees)
This is average a small shop will charge. Remember that this will not apply to if you need other things such as Master or Slave cylinder.
Under $600 is a reasonable price range. Dealers will charge $$$ as they go by the book.
As long as the mechanic can do it fast and right for under 6 hrs, you get less to pay out of your pocket.
Go to a reputable Honda guy and knows what he's doing.
Old Apr 19, 2012 | 10:52 AM
maharajamd's Avatar
He said his HP is is at or below 350. The JnR would be complete overkill here. Not to mention 3x the price he needs to pay for a clutch.
If not OEM just go up a stage. ~$600-700 clutch.
Old Apr 19, 2012 | 11:49 AM
giggity's Avatar
I don't know the stock weight of the oem flywheel, but I loved the swap to fidanza flywheel and a stage 2 clutch on my old eclipse. You have to relearn how to drive stick shift as the timing with your feet will be different, but nothing a good driver can't acclimate to.
Even though I was only pushing 215hp and the clutch could hold 410lb tq... I got it because it could take repeated launchings at 3k rpm and still grab each gear like a champ. If you are into modding, the light flywheel and UR pulley are great mods.
Old Apr 19, 2012 | 11:53 AM
be careful.
using a light weight flywheel, you would need sprung clutch disc.
the stock flywheel is dampened.
Old Apr 19, 2012 | 12:03 PM
dstah's Avatar
http://www.phoenixfriction.com/p-238...cord-9-38.aspx
Anyone tried these clutches before ? I found a good deal on this
Old Apr 19, 2012 | 12:05 PM
^ i would stick to OEM.
Old Apr 19, 2012 | 12:17 PM
giggity's Avatar
I went ACT stage 2, don't know if they make one for the TL though.
I miss driving stick
Have a 5AT and use the SS to get through withdrawals lol
If there is a dampner on the stock flywheel a good after market will include the correct needed items to fit. I did have to relearn as you could feel it when you released the clutch at the wrong rpm more than the stock. I would think there would be no issue if you know how to properly rev match. (no power shifting)
dstah's Avatar
My friends uncle ( mechanic ) said he can get the " luk " brand clutch for around $260. He said if I bring my own clutch he wouldn't warranty if anything happens .. But if I buy the clutch from him he said he will warranty if something goes wrong.
Old Apr 19, 2012 | 12:19 PM
dstah's Avatar
& of course im going to double check the parts he gets just to make sure it's the correct ones I want ( luk oem replacement )
the LUK branded is OEM.
thats why he's warranting it.
this is what I pulled out of my car.
my scored pp.
Old Apr 19, 2012 | 12:20 PM
maharajamd's Avatar
^Then I would go through him, pay the extra little premium, so that he will warranty the work.
Old Apr 19, 2012 | 12:34 PM
dstah's Avatar
I guess thats what I'm going to do. Get parts with him and have him install it. Hopefully when the new clutch is on i can spin my tires again
Old Apr 19, 2012 | 12:35 PM
tire spin is bad! and probably contributed to your clutches death!!! lol
Old Apr 19, 2012 | 01:16 PM
dstah's Avatar
Lol ! I'll try not to abuse this clutch :p
Old Apr 19, 2012 | 01:19 PM
^my tires are bald, I'm about to go abuse them!
Old Apr 19, 2012 | 01:24 PM
dstah's Avatar
If only you lived in Los Angeles. I'll hook you up on tires
Old Apr 20, 2012 | 10:48 PM
kingkong_dav's Avatar
KingKong_Dav
a good o.e clutch will always run you more than 1200 installed, parts and labor plus 1 year warranty. now if you went with a clutch from oriely or autozone it is cheaper. if i were you dstah, go a little better and get a good clutch that grabs, and youll be ok. ask your local part dealer they have performance clutch.
Old Apr 15, 2015 | 01:39 PM
jdw1's Avatar
I have done some reaserch but stil lhave a question. I'm sticking with OEM, I have a J pipe and AEM v2 but it's just my DD. I would like to skip the expensive a$$ flywheel. Any one done this with good or bad results?
Old Apr 15, 2015 | 02:06 PM
if the fly wheel is fucked, you cant skip it.
that's like getting sick and the doctor only cures it half way.
Old Apr 15, 2015 | 02:17 PM
jdw1's Avatar
I have a hair over 100k. How would you tell it "definitely" needs replacing?
Old Apr 15, 2015 | 02:25 PM
does your clutch need to be replaced?
the clutch plate(pressure plate) mates to the fly wheel by rubbing or spinning against each other.
usually if clutch is toast, fly wheel is toast.
but you will only know when you tear into the clutch to inspect fly wheel
Old Apr 15, 2015 | 04:37 PM
jdw1's Avatar
I could make it a while longer taking it easy but when I seldom get on it and shift quick It slipps very bad.
Old Apr 16, 2015 | 06:40 AM
KN_TL's Avatar
When it slips on quick shifts, does it gradually engage or does it continue to slip?
If it eventually engages on high rev shifts and is fine otherwise, you may not need a clutch at all.
Mine would do that all the time before removing the check valve from the slave and even with that, would slip off the line applying more than stock HP. When I went with a higher end clutch, my stock unit wasn't all that bad.
Removing the transmission isn't trivial so if you're going to do it, do everything.
Old Apr 16, 2015 | 08:35 AM
jdw1's Avatar
It bounces off the rev limiter long enough for me to just let off thinkingWTH. Normal driving is seemingly fine but I didn't get a sports sedan to not be able to have a little fun every now and then. I just did the big A14 so I don'treally or can't really come off another 15-1700 for this job ATM. That's why Iwas trying to see if the FW could be circumvented.
How long does that check valve removal take? Iread a little about it in that thread but it seemed like a thing for ppl that romp on their car more. I only drive what I would consider hard, maybe 5% ofthe time. That being said, when I do I would like the clutch to engage and notslip.
