ATLP J Pipe and Exhaust Gasket HELP!
I just bought ATLP j pipe, test pipe, and exhaust.
But I don't have any gasket for it. Do you know where I can get some?
I went to advance auto part and was able to get 2 gasket for the mufflers section and 1 gasket from the test pipe to the exhaust mid pipe.
I still need the j pipe gasket, the j pipe to test pipe gasket, and the exhaust mid pipe to y pipe gasket.
any info would be appreciated.
the gaskets should have come with the jpipe if it was new. i had the hardest time finding replacement gaskets for the cats to the jpipe connection and never found any that fit just right. you'll have to order them from rv6 or heeltoe.
i did find the gasket for the jpipe to test pipe (3rd cat) at napa auto. the center opening is 2.5" and the bolt to bolt is 3.5", and the gasket is an equilateral triangle. if you're going to order the gaskets from the vendors, this gasket will come in the package.
or you can use red rtv gasket maker but i would rather use actual gaskets.
I am going to buy the exhaust gasket sheet and cut it out. Than used the copper rtv gasket maker to help with the seal just in case it may leak.
Former Sponsor
should have came with them if they were new like oP said, or if its the endless one we use crush washers, same as OEM.
Any local store should carry them, or you can use rvt which is a little messier, but a lot better than a gasket that will fade away/crush over time etc..
InFaMouSLink
10-27-2015 06:52 PM
johnpancakes014
09-27-2015 12:58 PM
