Atlp
Old Nov 20, 2008 | 11:11 AM
sprtstr012's Avatar
Atlp
will the Atlp sound good if I used my stock resonator and jpipe?
Old Nov 20, 2008 | 11:33 AM
OneWickedTypeS's Avatar
MY KBP IS BTR THN URS...
HELL YA...
Old Nov 20, 2008 | 11:38 AM
blkaspec's Avatar
Full of water...
so you would cut the ATLP exhaust up in order to install the stock resonator?
Old Nov 20, 2008 | 11:41 AM
sprtstr012's Avatar
so why do ppl get the atlp jpipe and a new resonator if flit doesn't affct the sound? what does new jpipe do?
Old Nov 20, 2008 | 11:45 AM
sprtstr012's Avatar
if I didn't cut the exhaust to intall the stock resonator does the atlp have a built in resonator or does I have a non resonated sound?But I would have to uses the stock jpipe and cat converter right...purchasing a new jpipe is optional? I'm not sure exactly wat it does anyways. if I just got the atlp and nothing else that's enough to take it to a shop and have it installed right?
Old Nov 20, 2008 | 11:51 AM
blkaspec's Avatar
Full of water...
here is the stock layout
the ATLP does not have a resonator.
you would have to use the stock j-pipe and cat if you didnt upgrade.
it is optional.
you can install just the catback exhaust without purchasing anything else, the only issue is the stock components have a smaller diameter so you will have decreased air flow before it gets to the catback.
if you go to the ATLP site you can see thedifference between the two pipes. the stock is a lot more restrictive and the ATLP has the added bonus of having the same length pipes coming out of each primary cat. if you are doing the exhaust it would probably be nice to spend a little extra $ and upgrade the cat and j-pipe.
http://www.acuratlparts.com/products/2/
Old Nov 20, 2008 | 12:01 PM
sprtstr012's Avatar
is it bad if there is less airflow, it passes emissions? also since there is no resonator is it a high pitch sound ? I've heard it being low toned how is that possible without resonator?and is it bad to have no resonator, emissions and is it legal to have no resonator and less air flow
Old Nov 20, 2008 | 12:12 PM
sprtstr012's Avatar
will I still get the low atlp quality sound without the extra pipes?
Old Nov 20, 2008 | 12:14 PM
sprtstr012's Avatar
will the gains be less with the stock pipes? less than a 10 hp gain without jpipe or cat converter?
Old Nov 20, 2008 | 12:22 PM
aznbo187's Avatar
A resonator isn't the only thing that reduces high pitched tones. If the exhaust is properly tuned for sound, it should be able to create the desired pitch without any harsh irregularities. We can add a resonator as an added cost, which will overall quiet down the note by a pitch.
The resonator doesn't affect emissions, the catalytic converter does. We have a Hi-flow metallic converter (#200 Cell) that will give you the best of both worlds, emission and performance wise.
Old Nov 20, 2008 | 12:24 PM
aznbo187's Avatar
You will still get the ATLP sound with out the J-Pipe.
The J-Pipe with the exhaust will get you more gains, but you will still get about 9-10whp with only the exhaust.
Old Nov 20, 2008 | 12:46 PM
sprtstr012's Avatar
is it that much louder without a resonator where it will irritate me or there ppl or is it a good volume? is the exhaust really loud when not moving like at a light?
where can I get the atlp besides acuratlparts.com because there stopping selling them idk y
where can I take it to get installed and how much is labor?
Old Nov 20, 2008 | 01:11 PM
blkaspec's Avatar
Full of water...
well, atlp is acuratlparts.com, but i think heeltoe.com is selling them too. they are making a version for the base TL so i think that if they are no longer making them that is why. labor should not be too much and you can take it to any exhaust place to have it installed. i had my j-pipe and race pipe installed for like $25, so i wouldnt expect the full exhaust to be too much...
acurajj
Feb 14, 2016 02:28 PM
IIDXholic
Oct 8, 2015 07:53 AM
jmaxima03
Sep 27, 2015 10:22 AM
Billu99tl
Sep 13, 2015 11:30 AM
obsessedmotors
Sep 10, 2015 10:49 AM
