Anybody else have the UR Crank Pulley?
#81
Import and Domestic owner
Just came home and did two more runs. I am definatley pleased now, first run 5.53, and second run 5.72. Now I am in the fives I am hopeing for the low 14's in the quarter. Definately recommend the pulley.
#82
#83
CTS-V Import Slayer
I also got a belt from NAPA ....the crossover NAPA part# is almost the same as listed above for Dayco.....NAPA Part# 060820 Micro-V.
Cost me $28.19...but the list was $41.76? Probably a base price listed for discount shock of something? Most likely could have gotten for the $25 listed above if I would have told them I worked for a local shop here in town and got wholesale cost?
#84
I just installed it yesterday, and I used an dayco belt and it worked fine. Now here is where my problem lays, after installation I took it out with a stop watch, and clocked it 0-60 before and after pulley. Same times no difference right away. The instructions say that it takes 5 to 7 days for the ECU to adjust. My 0-60 times were ( with 5AT) before aem cai first run 7.5, second run 7.3 after cai first run 6.6 second run 6.4 and after install of pulley same time. This is immediatley after installation. all these runs are with 2 people in the car, so they are faster without all the weight. About an hour later I was driving home and I noticed an increase of power. And in front of me was a mustang gt about 03, with straight pipes coming out the back. I passed him on a double line and got in front of him. He pulled up on my tail, and I hit it. The whole way down the street I was pulling on him. I was definately faster, I couldnt believe it! So right now I am going to do my 0-60 time run and I will post the times with only me in the car. And yes dayco belts will work.
did you install it yourself? and if you did what was the torque setting for the bolt? Because I have seen 47 and 180?
#85
Just had my pulley installed Sunday Everyday i have noticed considerable gains in torque mostly in the midrange, the RPMs zip through alot faster. Thanks to all before me that did this mod, I was convinced and now very pleased!!!
#86
Ryan Christopher
Harmonic Balancer
Just wanted to shed a little light on the Balancer. I used to have a 97 Prelude with the H22A4. Great car lots of Engine mods, including the full UR set up and 8lb flywheel. Back to the subject, Honda uses a internal harmonic balancer. It is attached to the the crank with a belt in the same area the timing belt is located. It was always a debate to if removing it would hurt the motor. I kept mine, but had replaced the belt with a gates belt. So changing the pully really does not effect it in that way. I had the pullies on for about 25000 miles and no real problems. I am interested in doing this mod, but not looking forward to removing the crank bolt( always a headache ). I cant say you will see 10-15 HP but it will help the motor rev quicker, and that is a good thing. Good luck with the projects, and if you get a chance post some dyno sheets!! As I do my mods I will dyno and eventually post the results.
#87
in any case, i can find no such device(s) on the TL:
2004 TL crankshaft
2004 TL T-belt and camshafts
2004 TL crankcase/block
pls enlighten me. i had considered this mod, but typically run my engines well into the 200k mark. w/out removing the crank for balancing/blueprinting it ssems like too much of a risk...
#88
Former Sponsor
I don't understand the problem. If the engine is internally balanced, then how would the pulley (external part) have any affect?
The "balancer" part or harmonic balancer you talk about comes from engines that are externally balanced and have a counterweight cast into the damper, hence the merging of the two terms. This is not the case with Honda engines as these engines are internally balanced.
#89
Ryan Christopher
Originally Posted by mbwmn
i worked @ Honda dealers thru 1990 and was unaware of any of their (automobile) engines having internal harmonic dampers or crankshaft counterbalance devices. 1997 must be different?
2004 TL crankshaft
2004 TL crankshaft
#92
Former Sponsor
Originally Posted by PeterUbers
So if the crank pulley does NOT produce any extra hp .. (or FREE up any extra hp, etc.) what is the advantage of an engine "revving" faster.
#93
Cosmo
If you look at the picture of the crankshaft, you will notice what looks like a bicyle gear, that is normally where the balancer would be located. Most of new 4 and 6 cyl imports do not balance externally. The balancer is either in the motor, or they spend the time to balance them.
I did the "pre-dyno" before the pulley and have not had time to go back and have it dyno'd again to see exactly what this does in the way of HP/Trq. I will say that it is a bit quicker now.
#94
the "bicycle gear" device drives the timing belt. it is usally located directly behind the crank pulley and behind a plastic dust cover. if there is a "star-shaped" peice attached to the lower t-belt pulley it's usually the pulser/trigger (for the electronic ignition) or the drive gear for the oil pump (like on the TL?). the TSX uses crank gears to to drive counterbalancer and timimg chains.
these (TL) cranks are naturally balanced (to some extent) by virtue of their "V" configuration. internal balance shafts that are chain-driven off the crank shaft are typically not necessary in a "V" configuration because of the natural primary balance afforded by the "V" design. they (counterbalancers) can be readily found in some 4 cyl engines. these "inline" configs do not have the advantage of the natural primary balance the " V" config offers...hence you see the "internal balancers" Black_05_TL mentioned above on the TSX.
by the way, disconnecting these internal crankshaft counterbalancers on some motorcycles (like ZX11's and ZX12's) can offer significant horspower gains (w/ decreased internal engine component life and increased vibration).
Honda also seems to spend considerable care in design and construction to limit the amount of weight variation of there pistons and rods; much more time and car than most domestic US manufacturers. this contributes to superior "internal balance" of both their 4 and 6 cyl engines.
HOWEVER,
i'm off track here...
it is important to understand the difference between "balance" and "damping". we need to consider crankshaft damping, as that is the function of the stock crank pulley. almost all egines are (to some extent) internally balanced (by a balancing device or carefull quality control of rod/piston weights), but the crank is not internally damped. if the crank were removed and each section (journal) matched to individual pistons/rings and rods it held, then lightened, a damper may not be necessary. (this is what some mistakenly refer to as "blueprinting" an engine, but in reality is "balancing" it). this becomes cost-prohibitive and not particularly of great advantage to the average joe/soccer mom. (these guys do great crank work for motorcycles and smaller Asian 4 cyls:
Falicon Engineering)
unfortunatenately, we TL owners still need crankshaft dampers (in MY opinion, and more importantly Honda's opinion, and possibly PeterUber's opinion?).
here is a link to an explanation (begging to be read) he provided earlier in this or another thread:
another internet opinion about crank pulleys here
(pls take the time to read this and be prepared to discuss it should find it necessary to reply).
in summation:
don't be mislead by others who don't know the differences discussed here, or don't even care to investigate the facts. make an informed decision and be prepared to live w/ the results and possible repercussions.
if you are searching for cheap horsepower and don't keep your car very long then a crank pulley might be just the ticket for you, especially if mommy pays your repair bills...!!
but, if you run your vehicles into very high mileage (365k on my pickup, over 100k on one of my motorcycles) and repair them yourself as I do then you might consider that Acura (and almost all other Asian and European manufacturers) all use harmonic dampers on the end of their cranks for a reason. my limited very experience w/ domestic manufacturers indicates they use them also. if they ALL could save the money by manufacturing a solid piece instead of the multi-piece, rubber-sandwiched pulleys don't you think they would? if the trade-off of gaining a few horsepower vs. the possibility of decreased life of internal engine components is worth it, then order up and have someone install a UR pulley; they seem to be touted as the best. BUT, i'll be the first to tell you i told you so when you complain that you need a bottom-end rebuild "prematurely", and that Honda's product is sh#t...
ps: pls wave when you pass me w/ your crank pulley!
pps: i read somewhere on the internet that there is something called "parasitic drag" caused by the oil and water pumps on these engines. it said that if you just disconnect the oil and water pumps you'll gain horsepower. these cars don't really need these anyway: they are "internally lubricated" and have "internal cooling". anyone willing to test? i'll help w/ disonnecting them...then we can race to see if yours is faster...
#96
Originally Posted by ed99
I am interested in getting the pulleys but I heard it is not good if you are running an aft mkt system with over 1000watts. Is that true???
1000w / 12v = 83.3amps (roughly) just for the stereo alone. add this to the baseline power consumption of the vehicle @ idle w/ ac on (ac alone = 40+amps?) and you're prolly pushing the limits of the stock (120amp???) alternator w/ the stock pulley. a larger capacity alternator and/or a good capacitor might be called for, regardless of what you do w/ the pulley.
#99
Just think of all the weight you could save! All those fluids, just being pushed around at no particular velocity/presssure! What a waste!
#100
can anyone give me some insight on installing this the UR ??? I have had this one in my garage for a month or so now and i want to get it installed , i have some free time this weekend so i was hoping to get it done then.. Did anyone take pics during there install ?? Anything i should know before starting this project ??
#101
CTS-V Import Slayer
#102
Check that the part number matches the
number engraved on the back of the pulley.
Installation Instructions
1997-03 CL All / 1999-03 TL All / 2001-03 MDX / 1998-03 Accord V6 / 1999-03 Odyssey V6
• Alternator & A/C Belt: Accord, CL & TL: Use Gates K060441 (44 5/8” or 1135MM)
MDX: Use Gates K060445 (45.25” or 1150MM), alternate belt size use K060441 (44 5/8” or 1135MM).
Odyssey: Use Gates K060445 (45.25” or 1150MM)
• Power Steering Belt: Use Gates K040425 (43 1/8” or 1095MM)
Gates Brand belts
• Alternator & A/C Belt: Use the stock length belt.
This is the model number on the Gates (recommended)belts...........hope it helps unless you have a 3g,sorry I didn't check
#103
yea i already got a new belt so i think i should be good , i haven't looked but i know on my old integra to remove the pulley i had to unbolt the engine mount in order to get the belt off , i just wanted to make sure there wasn't any steps like that ??
#104
I LOVE MY TL
did anybody look at the part number on the UR pulley to see if it match the paper?i was just wondering ..the last 2 number i didnt see it on the pulley...its suppose to be 02 but then there was words on it.saying rev somthing then i see a 06 instead of a 02 like on the paper..anybody can help me?is it the right one or wrong one?
#105
Former Sponsor
01= Black
02= Polished
03= Red
04= Blue
However, UR no longer does colors. Polished is all that is available.
#108
Former Sponsor
Originally Posted by stavebomb
Does this void the warranty at all, and once its installed can the dealership tell that it is in?
#109
I LOVE MY TL
i have the OEM pulley but not the UR pulley..the UR pulley is in my car right now soo i cant take picture of it..but anyways Joshua is a Great guy. i got my pulley the next day..LOL i cant beleive i got it that fast!!!!the UR pulley was soo shiney and light,also i got the Gates belt..i was gonna go with DAYCO belts or somthing like that at Pepboys.but i got scare soo i went to Napa and i got it from them for 26 bucks...Im SoOoOo happy with my pulley..i can feel the differents..the Rpm move up quicker and i feel like the power is there when it is needed .anyways here is the OEM pulley picture ...
#112
wait for me!
Got my UR pulley installed today.
The guys @ the shop couldnt get the GATES belt on so they left the stock belt on...does any1 know if im going to run into any problems or should i be fine?!
#115
#117
wait for me!
Well when the guys compared the two (stock and Gates recommended) that there was a verrry minimal difference in size. He explained to me that there is a tensioner with one of the pulleys that adjusts to the belt to give it the right fit. I just wanted to ask on here to see if anyone could offer anymore insight. HOW LONG FOR EVERYRONE WITH THE UR PULLEY TO FEEL THE DIFFERENCE?
I've driven like 40 miles and im already noticing an improved throttle response and faster reving. It could also be psychological LOL
Paid 90 bucks for the install.
I hope the belt dosent fall off
#119
Former Sponsor
#120
Former Sponsor
Originally Posted by SilverStoneTTL
So I'm thinking of getting this..but do we need to buy a new belt? How does that work? What belt do most people get (brand wise)?
And to JJaber, on many of the J series engines it gave about 8-10 hp.
