Another AEM review....
Team Nighthawk Mambo King
So I waited for over 3 weeks to get this AEM CAI from Performance Parts in CA for $217 shipped....got it today at around 2PM and was installing it by 3:30.
The install went smooth, hated the fact that I had to drill out a couple of rivets so that the resonator could come appart into two pieces therefore removing the unit took longer than was installing the CAI.
One step was to drain a gallon of antifreeze since you have to disconnect and reconnect some coolant lines but I just lined up the hoses I was about to change and quickly swapped these w/out having to drain the radiator... ..a few drops of coolant dripped out ( blue..uhmm) but I had a few paper towels ready for this.
After that all else was as planned, the instructions were simple a few pictures were kind of misleading but I'm glad this was not my 1st .
There was no mention about removing the front driver side wheel as I did which made the install easier, also a section in the instruction booklet that says to cut and remove the shrink wrap on the O2 sensor, I didn't just made a cut to separate the wires to be able to reach the connector to the actual intake maintaining the insulation of both and the sheath that these were wrapped in.
Sorry no pics since the forecast was rain and I was under the gun hoping to beat it... maybe tomorrow I'll take a few and hope to answer any questions on the install.
OK now for the review:.....I can say that the whistle sound I hear is not as pleasant as the VTEC sound from a DOHC VTEC...just not as powerfull... , but ...that is just the sound my friends, I noticed an immediate increase in response...very noticeable during take offs....I'm impressed...
After seeing the amount of parts I had to remove to get this thing on I know I must have lost at least 2 lbs just in parts, nuts and bolts... , so I give it a 9 on a scale from 1-10..10 being a turbo....
Pics to come tomorrow...sorry it started to rain as I was putting my tools away....
Hek i installed my aem over the weekend as well. The removal part was a bitch. But now I am happy. And yea we atleast lose 5 lbs off that resonator. Thing is a bear. The whistle sound does not bother me so much. The thing roars when you are above 4K. I lit it up at a light near a huge wawa gas station, I glanced over and I caught the eye of a g35 coupe owner. Sounds bad ass.
You mean the optional off road use power adder where you take the IAT sensor and hook it in to the treaded portion? Or do you mean removing the coolant lines?
Pics!!!
Originally Posted by narmeen
HEK How much do you like it? Can you hear the sound increase while at around 3000RPMS??
I want to add as a comparison to drinking out of a straw vs the straws they sell for kids that has all these bends so they can see the fluid going thru....it takes much more effort to use the one that is not straight....
Originally Posted by TL Tita
is the installation hard? fairly straight foward? I mean i dont want to pay like a 100 bucks to get it installed by a professional.
huh, ur 2 hours away. Arrgg anyone else who wants to help me out?
AEM filter replaced with ApexI Power Intake
Hek, great review!
For all AEM modded owners, do you know what the piping size is? I want to switch out the AEM filter with an ApexI. I couldn't get a definite answer from AEM directly. The ApexI is 80MM.
Thanks.
Thanks.
THanks. When i get the intake, i def will consider ur help. When i had my M3, i was going to go down to maryland to get my supercharger installed. Nope, im not a female but the mall thing would have been a good place to spend time at. Let me give some thoughts.
I did not do it...does it make a difference? Sound, HP gain?
Originally Posted by hondasaurus
Hek, great review!
Thanks.
Thanks.
I hope that the size is the same all around because if it means I have to take off the liner it will have to wait, but maybe at lunch when and if the the rain stops I'll go outside and use my micrometer to measure the tube....
SSM 6MT
Hek, great review!
Thanks.
Thanks.
Originally Posted by rstark
I just measured since it's still in the box, with my digital calipers, it's 83mm outside diameter where the filter goes.
Thanks for helping out hondasaurus, I was walking out to my car at lunch yesterday with my calipers and didn't realize it was pouring rain so I turned back to my desk....BTW which color did you take, my son says I should have gotten black....
SSM 6MT
Ak Ting Up
Like I mentioned before, I had a DOHC and when in VTEC there was this loud growl like it was coming from an exhaust instead of an intake, now with the SOHC, the VTEC sound is raspier....at 4k and over, combined with the dual exhaust I can say it sounds great, I want to have my son drive it while I follow him in his car to have a more exact review, since as is I can only hear it when I have the windows rolled down but can't tell with the windows are up...anyway Honda calls our intake systems COLD AIR, mostly because it takes the cold air from outside the engine compartment...but it's too restrictive to say that the vehicle would benefit from it compared lets say to the one in the Odyssey...too many chambers and bends compared to one bend in a tube that is smooth.
Originally Posted by AcuraVic
HEK, thanks for the pics and initial review. My question is, where is the air filter? Do you have to take off the front tire to change it?
SSM 6MT
Removing the stock resonator was a b!tch. The instructions weren't as clear as I hoped (the images were misleading). When you remove the cover for the stock intake next to the battery, make sure you pull out the round intake underneath it and this will make removing the lower resonator piping smooth.
As for the wheel well removal, you have to remove one clip and two 10mm screws underneath the car and in addition to the three clips to remove in the instructions, I removed one more at the top of the fender well and this opened the fender liner well enough to work with. Please note, the clip at the top of the fender well is smaller than the other clips, just remember that when you re-install the clips.
The installation was pretty easy, and I'm very happy with the results. AEM is a fine intake. I also moved the IAT sensor to the intake. Love the sound and the butt-o-meter says it's making more HP.
AEM Install
Well, I spent a few hours yesterday installing the AEM CAI.
Now, I have never worked on a car before in my life, not even changed the oil in one.
The directions were pretty straight forward. Only tough part was with the coolent tube. I did not drain any coolent, just tried to change the tube out quickly. I think it spilled a few cups of coolent. Checked my coolent level after the install and it was still a little over full.
Some of the bolts were tough to get to.
All and all, I think it took me about 3 hours start to finish. (a lot of the time was trying to find where the picture matched up.)
Only whistle I have is in 1rst and 2nd and very low RPMs. Really have to listen for it with the windows down to hear it.
Car sounds rather normal, maybe a little more rumble, at all RPMs until I hit VTEC.
With VTEC the car really opens up and is much more "throaty" and growls. Not annoying, but very nice.
I do notice a little performance improvement in that the car seems more responsive to the throttle.
Just did it this weekend, so dont notice any gas milage improvement yet.
So all in all, it is very easy for a DYI. Take your time, buy a few beers, and ask someone to hand you the 10mm and 8mm a lot.
My Review:
I installed my AEM CAI last night...
Lets not talk about how long it took me... well more then double if not triple what it should have...
Anyway, for those of you with the front lip, be warned this is VERY VERY hard to get CAI installed unless you want to remove the lip which would require you finding that tape stuff to put back on...
First part, I took out battery, and then removed the breather hose and the top part of the stock intake.
Next I got the coolant lines off (I spilled some from the hose flying when I yanked it, but other then that not to much.) I see no need to drain any coolant because no matter what some is going to get out. But its very minor.
Next part was the bit**... I took wheel off and I was able to get all of the fender removed but the front part (yeah the one you need the most, lol)
Ya see I have the front lip spoiler and well, its not made to come back off and some screws that hold it on attach to the fender and are covered so you cant get a screw driver to take them off...
Put it this way, if you read the CAI install instructions and then go look at your car (if you have front lip, you will understand.)
Another idea, that "Rstark" gave me (thanks) was to drill a small hole in the lip on the fender side so you can put a screw driver in... I ended up not having to do this but it would help a GREAT deal, and you can always seal the hole with some gray/black rubber...
Anyway, next I got drilled the 2 spots it stated to get the res. off the intake... I took out the bolts I could see, and it turned out to be one more out of site you have to feel for. After all of this, it was home free...
One thing I found, when I installed the new intake was the breather hose AEM gave me was much longer then needed. I cut about 2" off mine and still have more to if I need, but you don’t have to cut if you don’t want... I Also notice that the intake does not go to far onto the eng up to the stop point. You could counter act this by not putting the rubber sizer on as far I guess but I put it all the way on the intake side which made it not reach eng as far but still was on enough...
My driving xp, well car started up fine. I let it idle and update the navi for its 10 min like the navi wanted... Took it out on street and drove it light for a little, then I parked, shut car off, started and started to drive, and beat the crap out of the gas...
1-4 gear I can hear the whistle and hiss when it shifted gears when it did under 3k rpm & higher it made a nice growl sound...
One thing I dislike is when I shut the car off it makes a fart/clunk type sound from the intake kind of like an air compressor turning off..
Oh and my mpg is like 2-3 lower... I did move the ATI sensor, so I feel that may be why because it makes the car use more gas which does = more power but it at cost of mpg...
With regards to that, the ATI sensor does not fit well on the intake. It does not screw all the way up to the 0-ring, it gets tight before then... I got it close using a big ass tool but didnt wana break anything so stoped... Turns out a lot of people had that problem also...
Overall, am not yet sure if I like it or not... Lost gas milage, and got some sounds I dont like, as well as ones I do like. But I guess thats the cost of getting more HP... Always has + and - to mods...
Anyway, if anyone ever needs help installing one in ORL-FL I dont mind to help, (or by phone/message if out of area.) as well as if anyone has ?'s about installing one with a front lip.
I want to thank Rstark for his help, he did guide me with a few things over the phone, so props to him...
I like my AEM intake...but the only thing I dont like is the whistling/hissing sound. I get it anytime I accelarate in 2nd, 3rd and 4th gear...Intially even if I just touch the gas pedal (at lower RPMs). It lasts for like a second or 2 and then it goes away....but everytime you accelarate, it always comes for a little bit.
BigB2K5 - r u having the same issue??? Anyone else with the same deal or Is it only me...Its very annoying!!!! Please let me know if anyone else with AEM Cold Air Intake is experiencing this...so I will know its not only my TL.
Otherwise, it kicks Ass!
Yea, mine does it 1-4 and sometimes a little in 5th.
If I am on gas VERY light I wont hear it... If I GUN it I wont hear it, but if I am like moderate I here it.
Does yours make a strange sound when you turn your car off also?
You can only hear if you open door and then turn off car, or maybe open window.
Mine makes this loud sound like its releasing lots of air and it sounds so rice type....
Yeah - U r right....when I am on gas moderate or light - I can hear the sound. ALso when I start my car - @ idle I also hear a little hissing/whistling sound.
I havent noticed the turning off one - I will try to hear for it today when I go for lunch or either when I get home...will let u know!
So we did our installs and we are happy?...happy enough to admit that we've also installed the license frame or stickers from AEM??.....
Not me ....my son did on his car when he got the AEM V2...and U?
No sticker or frame on my car,
Originally Posted by DARK6mt
BigB2K5 - I recently got front lip installed, now I have CAI coming tomm, how can I intstall without removing the lip?
thanks in advance.
james
thanks in advance.
james
Now the hard part will be screwing the braket back on... It took me like 1 hour to get the screw back in because you have to get the bracket lined up, and screw in with your finder with your hand at an angle... once you get screw in enough you can fit the screwdriver tool in to tightn it...
Another option I was advised, was that you can drill a small hole in front of the screw your going to try to take out and put a screw driver through the hole... then fill hole in with something... Its not in a spot anyone would see really...
Hope this helps some... You will prob understand more once you go to do it..
Dr. Feelgood
Just did mine a few hours ago. Took me 5 hours, 3 of which I was trying to remove the damn resonator! That thing is a bitch to remove. The bolts are also way back there as well. I hear the whistling noise when stepping on the gas moderately hard, but not when pressing lightly. I've only taken her down my street breifly so I didn't really feel a difference. I will open her up on the highway in the morning to see if there is any power gain. Looks cool though
CTS-V Import Slayer
My Review:
This install....done by a total newbie...if they did their research on Acurazine 3G garage beforehand would have been less than two hours max!
Use the information man! Thats what its here for! Anyway...congrats on the install, hope all goes well from here. Sorry you felt you had mixed reviews, but I think you are underestimating its value for sure! And if gas milage is really something you are worried about.....WHAT THE HECK ARE YOU DOING PERFORMANCE MODS TO YOUR CAR FOR? That almost makes one question your sanity! Why one would do performance mods and expect higher gas milage? Dude, you are gonna be flooring it more for starters!
CTS-V Import Slayer
Dr. Feelgood
Wow! You are right! I gave her some gas today and she responds better and feels more powerful. I not sure how much more stronger she is, but I can feel the pull with less resistance. I was skeptical but not anymore. I need more mods!!!
Dr. Feelgood
I'm glad it sounds more sporty than it does rice . I want the comptech exhaust next after I get my a-spec body kit. I never thought I would do these things to my car, but the TL is so exciting to own. This is a great forum by the way. Lots of useful information.
