To ALL Need Help PLease
Supercharged 2005 TL NBP
I was wondering if anyone has a diagram of the ecu and knows what each pin does, i'm trying to install my air/fuel ratio gauge by hooking it up to the ecu, any help would be appreciated thanks again
~Jason
~Jason
DER NEUE ^
This is for a 2006 TL 6MT and A/T ECU, 04/5 could be different:
...................................pinout color
Ignition Coil 1...............A20 YEL/GRN
Ignition Coil 2...............A19 BLU/RED
Ignition Coil 3...............A18 WHT/BLU
Ignition Coil 4...............A17 BRN
Ignition Coil 5...............A16 BLK/RED
Ignition Coil 6...............A15 BRN/WHT
Injector 1.....................A21 BRN
Injector 2.....................A31 RED
Injector 3.....................A30 BLU
Injector 4.....................A29 YEL
Injector 5.....................A28 BLK/RED
Injector 6.....................A27 WHT/BLU
VTEC solenoid..............A22 GRN/YEL
MAP sensor..................C5 GRN/RED
Crank sensor...............B17 BLU
Cam sensor.................B8 YEL
Knock sensor...............B6 RED/BLU
IAT sensor...................A5 RED/YEL
Speed sensor..............B19 BLU
Pedal position sensor..D3 RED/BLU
Ignition........................D6 BLK/GRN
Ground........................A1 BLK
Sensor Ground............D7 GRN
DER NEUE ^
Ok, there you go 04/5 ECU, some difference:
Ignition Coil 1...............E20 YEL/GRN
Ignition Coil 2...............E19 BLU/RED
Ignition Coil 3...............E18 WHT/BLU
Ignition Coil 4...............E17 BRN
Ignition Coil 5...............E16 BLK/RED
Ignition Coil 6...............E15 BRN/WHT
Injector 1.....................E21 BRN
Injector 2.....................E31 RED
Injector 3.....................E30 BLU
Injector 4.....................E29 YEL
Injector 5.....................E28 BLK/RED
Injector 6.....................E27 WHT/BLU
VTEC solenoid..............E22 GRN/YEL
VTM VTEC pressure......E23 BLU/BLK
MAP sensor..................D5 GRN/RED
Crank sensor...............D1 BLU/RED
Cam sensor.................D7YEL
IAT sensor...................D16 RED/YEL
Speed sensor..............D14 BLU
Ignition........................E4 YEL/BLK
Ground........................E1 BLK
Sensor Ground............E2 BLK
31P (PCM A) below
31P (PCM A) continued below
Starting 24P below
24P below
24P continued below
Starting 22P below
22P below
22P continued below
Starting 17P below
17P below
Starting 31P (PCM E) below
31P (PCM E) below
31P (PCM E) continued below
