All in 1 about SRI - CAI (mostly SRI) :)
#41
After driving my Type S for a while with the SRI, I'm pleased with it. I'm leaving mine just the way you see in the pictures above (without the AEM sticker).
I can feel minimal boost with the addition of the SRI. But my J-pipe plus the SRI and the Throttle Body Spacer gives me nice gains.
#42
Received 6,470 Likes
^^^ Haven't measure that yet, but I will, if you want me to!
Before the SRI, I was getting 18-20/24-29 MPG.
sockr1 (07-10-2012)
#43
I don't think AEM copied your intake. If they did copy it, the bends would need to be actally identical, which I doubt it is. The design may look the same, but the airflow will be different.
As you say something about not wanting higher rpm with CAI - this will not give you power higher up.
Think of a vacuum, build a car like one.
I think CAI will gain more than just 1-2 hp gain over SRI. Remember that this is all IAT that will give you better hp. Your IAT's are probably much cooler with the stock air box compared to an SRI, which is why some people will experience no power gain from it. Even maybe that the car in untuned from a SRI the ecu will suffer bad ARF making it suffer in mpg's.
I'm not saying SRI robs power, I'm actually agree SRI to a certain point. With a design and airflow, the temps could see good IAT's if a person know's how to build one. With a bad design, AFR could be ugly and could wash the cylinder bores and cause premature wear.
So my remedy is if people with the JnR ecu can chime in on the powers they are making with CAI and SRI, people will start to change their games a bit and start to think that when the engine is tuned, people will realize that the J32 will make more power with IAT number less than Sri's.
But for now, I don't have the JnR ecu to play with, but I can say is that in stock form if you found a way to make it breath better, kudos to you. Without actual numbers of before and after, dyno's, we can still just give out more opinions to the community and help out clear other problems. More brains, more testings will get this done faster.
justnspace (07-11-2012)
#44
I was kiding on AEM copying my intake.
Think about bigger diameter intake pipe and longer one (CAI)
How will throotle pull all those air from there? Higher RPM
That's logic and that's what I read and saw everywhere
I am not going to talk about numbers on CAI or SRI, to me it doesn't make sense.
Reason:
How could you compare a SRI or CAI on a dyno?
This is not ecu or superch.
It totaly depends on the air.
Let's say you put the fan in front of the SRI. What difference will it make with CAI.
Many people here are thinking about easy swaps and daily driving.
You drive in city...will it still give you 1-2 more HP?
No
You have a CAI in city...sure open that throotle way more to make the car move
I didn't install CAI on my car but saw it on friends Type-S + read lots of post saying that CAI does reduce the low rpm power...or the take off
bouncer07 what do you say about covering the AEM SRI and cutting the air pipe before the resonator and extending it to the fender
(keeping the resonator)
Reason:
No
#46
Reason:
No
Reason:
No
So say you're stock and want to do an intake. 3inch is overkill for stock. To even think about going bigger is when you know you're pulling in more air. (Ported runners, bigger TB, etc) To even go say 3inch intake on a stock car with only an intake, you'll lose power as more air in, less exiting.
You're pullin in air not from high rpm, but the whole RPM band. Now intake design will either gain top end or gain more low end just like any header design, jpipe design, it all effects your power band. With many intakes that I bought and installed into my previous cars, you'll know that CAI will give you more peak hp than a SRI.
As your custom AEM intake, just get a good welder to seal it up after it is cut.
CAI vs SRI debate is all about preferences. If there was a ice/carbon box or cowl induction intake or even the style like pwdJDM's intake would look neat inside the TL's engine bay where the batter is located.
#47
So... played with the heat shield today
I took my small piece and with small pieces of card board, slowly by taking my time, created this...
Started from bottom...so right now there is no way air escaping somewhere else.
And only opened part is the right top part you see
When I will close the 2 right and left...boom no more gap to the engine from the bottom of the SRI tube
See the bottom?
Only gap...
and about to close
Nooo way heat getting in from the left side
I could also close the right side too but didn't want it.
Don't think it could pull lot of warm air from there + filter is aiming down...soo
I have some doubts about removing resonator or keeping it but cutting the pipe and extending it.
I check the fender with a flashlight....
The unknow tube... which is
iss right on top of the fender area... so close
air goes up from the fender and enters here directly...that close
so I have doubts on how will air go down in to the CAI area or if we remove the resonator and extend a pipe...
anyways
I replaced the pipe that I connected the air pipes
bigger diameter on the top area so it grabs all the air
it's a pvc pipe...after a long drive...still the coldest part in the engine bay
liiitle uphill
I really don't love starting from 0 with this car but I know on highway that intake will answer...
Will see..
See the bottom?
Only gap...
and about to close
anyways
liiitle uphill
Will see..
#48
takin care of Business in
Received 4,732 Likes
awesome work Meko...
about the debate between CAI and SRI, both will gain power when compared to stock, but SRI gives you more power down low and the CAI moves the power band in the higher rpm...
I agree with bouncer about the IAT...IAT's being close to Ambient Temps are very important for your power/performance....the minute the IAT's go high the engine pulls major timing....I have logged those parameters many many time and seen this....
I went in for a 4" CAI with a 4" inlet and 9" long AEM filter....the CAI was sitting right behind the radiator fan and sucking on that hot air and it got crazy hot....at which point i cut the CAI and made it into an SRI so now the filter sits in front of the fuse box....this resulted in lower underhood temps....
I will be modifying it to get some more air in from the lower vents, but this project will take some time
#49
Call me crazy, but the SRI combined with the J-pipe and maybe even the TBS lately has sounded and felt a lot huskier.
Getting a nice, throaty sound out of it. Seems like a little more power too.
#50
Thanks Anil, it's miuch better right now. I think I will try it by closing the top too.
I thought about going to a metal shop or something and make a custom box for that place and powdercoat it. I found one place but I am not sure yet. It might be costly.
I will give it a try tho.. I think
Show him and ask a price
How it looks rightnow
And dude you do everyhthing to this TL but why don't you cover the intake?
How are you going to modify the lower went? How about rain?
You have to cover that filter if you ask me.
I agree Steven.
Did you notice any performance lost after a long city driving?
I agree Steven.
#52
I got nice updates. Couln't upload pics last night.
Will today.
Will today.
#54
MEKO, you just went on my bad list LOL...
no i am not going to over the air filter....i have lost a lot of weight and am not putting the weight back on....another thing is I have a little hood pop and you can see the filter from the side and i like it, more fresh cool air....
yes my filter is exposed to a little water but people need to realize this that they wont hydrolock their engine from little drops of water on your intake filter....to hydrolock your engine your intake has to be submerged in water and you have to gun the gas pedal....
#55
haha
you just answered everything dude
true
and sooory i forgot the diet while writing that hehe
#57
very well done Justn....and you are using the stock air filter and box right?
#58
But, from 'Steven Bell's pics I don't think he has the bracket either. Steven - Have you had any issues with movement or anything?
#59
Well done Justn but I got some questions.
How is the sound right now, after removing the resonator?
Lot's of comments saying gets soo loud but can't trust those.
Here are my thoughts.
Did you remove the front fender?
Right side of the fender is the part where air goes directly upward.
Since no CAI, removing it won't harm the intake such as rain or other...
What if you take out the extended pipe you put there and add velocity stack?
Because your extended pipe is kind of facing down, and yellow arrows which are the air, goes directly in to that pipe.
Someone correct me if i am wrong, but that what I saw from looking at the fender with a light.
This is what another member did
Soory for the bad drawings I am in my psychology class right now
#60
I used the stock velocity stack near the battery.
I upgraded to a 2008 tl-s bumper. But I have not bought the fogs.
the velocity stack is sitting RIGHT next to the fog light opening.
I took off that piece you have drawn in red.
I took the factory velocity stack and stuck it right where the resonator used to be.
thus making it a true COLD air intake
MEKO (07-19-2012)
#61
@ browsing and posting in your class....pay attention
but Justn i totally agree with Meko...it slipped me completely to ask you if you had removed the little plastic piece in bumper's lower grille....
also if you removed the coupler and added a velocity stack right there, it would prolly end up giving you some more gains (IMO)
EDIT: too late....you already answered the question
#62
bro all he does is talk
soo im listening and typing at the same time
he thinks im taking notes but...yeah notes haha
Cool Justn. Give us update on the diffrernce.
Did it get louder?
Did it get louder?
#64
MEkO glad you took time to explain this as I certainly did not have patience to write all this up...but with that being said and since no one with a JnR tune has chimed in as many don't have their ECU's yet or what not.....
here is what I can say and have said a million times CAI over SRI and SRI over Stock....as you said with correct mods you are getting cool air to the air filter and get better low end torque........I dyno'd my TL-S with SRI and full RV6 exhaust and the gains were exceptional and same as with someone with CAI and similar set-up as me....
I believe also somewhere where Rodney dyno'd a stock intake box and then removed the intake box and it showed gains...again not real world as I know people will argue the point of hood being up and fan blowing and what not. I say this going 90plus mph you think you are not getting air flowing of course you are.....so heat soak will happen whether you have SRI or stock airbox...as the air coming in is in front of battery and at the point where engine gets super hot say sitting in traffic 90plus weather then you are screwed weather you are SRI or stock....this CAI may be at a slight advantage but I say slight because it is sitting away from engine bay yes but highway asphalt on a sunny day is not the coldest either and if can get really hot from other cars and whatnot....you get the point
so in terms of mpg I can say I has been better for me but also I am tuned so this helps my case better
I went on a recent trip and I went 450 miles and filled the tank up with 14.6gallons or so so roughly avg 30-31mpg going between speeds of 65-80mph so not bad whatsoever from 3.5L TL-S
On a sidenote MEKO if you do find a place that makes a custom box for your air filter please let me know as I been looking to do this but been delaying as other things in life have taken priority....
I say again after 3yrs with my SRI I am not disappointed and have not had no issues making me want to go CAI.....
I will say this though to be clear when I say SRI i mean this style set-up and not the ghetto remove stock airbox and place filter right at the TB !!! Yes this is a no-no and when someone is thinking of SRI they picture this then yes you are right that you will lose power over stock unit. The filter at this location is not receiving fresh air from nowhere!!!
Just my 2cents on this matter since it was a thread well written and I believe someone asked about a member with JnR ECU to chime in with SRI!
MEKO (07-20-2012)
#65
No, not so far. No changes or differences.
No issues whatsoever.
MEKO (07-20-2012)
#66
I totaly agree with you BostonSilver.. totally
Nicely summarized
Again, that goes to the posts that say stock is much better than SRI.
After you know what's going on there and did some mods, you really feel the difference.
I also felt the differrence after the shield I did.
I will go the shop today and ask them about a icebox.
If they can't do it, I will ask the friend at Bernardi Acura.
He is the one told me about it, he got EVO and STI + crazy mods under the hood
Thanks for the post again, yeah JnR ECU with SRI was asked..
Nicely summarized
#67
Boston as usual you wrote an AWESOME POST !!! well written and had all the info....
the only 1 thing which i kinda disagree with is CAI > SRI...its more of a preference....
if you see the CAI moves the power band towards the top end because of the longer tube....the longer tube is the reason the air has more velocity....where as the SRI moves the power band more towards the low end because of the "availability" of the air....now you will gain a lot more if you do something in the middle of a CAI and SRI and add a velocity stack and run it with a panty hose filter....this will gain you a lot....
I have seen this guy on the V6 performance forum (the guys because of which I went to a 4" intake) and he ran a 4" intake (medium length) with a velocity stack and a panty hose filter and gained more than 10HP to the wheels and all over the power band....the only thing which scared me was the panty hose filter....else I would have been running that right now....
#68
^ true indeed when the right mods are done and depending on vehicle and SRI location yes at times can yield more whp...but I was trying to keep it basic and in general perspective that CAI will yield more whp but saying this I can say peak hp and not power under the curve or low end, but didn't want to confuse anyone so just kept it simple!
When done right as you stated yes it can be very effective but at the same time.....for examply the guy getting 10whp running a panty hose filter, how long do you think his motor will last compared with someone running a better filter??
I mean if I didnt car how long I need my motor and longevity I would run a custom pipe and drill a hole in my bumper and run ram air style with no filter....Now I can guarantee I will yield the best numbers to the wheels but at what price and for how long? Not very long till I get all types of issues going in with all sorts of crap going into the motor.
p.s. I been thinking of cutting up my heat shield which I had removed from under the car which sits above the third cat....being that it is a heat shield, I could cut it and make it fit where it protects the air filter from the heat of the engine and helping the heat stay away....If I end up getting it on I will post some pics of the results
#69
^^^ actually a panty hose "filter" is more restrictive than even an OEM filter...so higher filteration
#71
Member wondered
take off from 2500 rpm on 4th gear
#72
^^^ did you gun the pedal? 4th gear 2500rpm 65mph to 4th gear 3500rpm ~83mph was about 6-7 seconds in the video....hence am asking this....
#73
Yes floored it... i'm positive
but not sure of the road... most likely straight
I-90
slow right?
I-90
slow right?
#74
Tested 14 gal
Stayed at parents
Drove to Boston for school every morning (20 miles)
Mostly morning traffics + city during the day
At night? Empty highways driving (20 miles) to parents
Drove like a normal human being... first time
in city it was around 19-20 MPG
yes i did floored it couple times after red sox game at night, couldn't hold my self
and lowest I saw was 18. This is in city
after half tank, MPG didn't change
said 19 all the time, sometimes 22 on highways (after driving 20 minutes)
as you know it doensn't change directly when the needle pass the first quarter
if you reset it during highways, then it will tell the exact highway MPG,
not the average till half tank
Total driving hour was 10 hours 40 minutes
Dist 280 miles
when I filled it, said 14 gal
13.9 to be exact
Morning time, it was 75+F
Day time, 85+F
Finished the tank in 2 or 3 days but did lot of city driving
I am actually impressed
half tank was 142 but this is when you drive like a normal person
no wot wot
no exhaust sound
no vtec
no intake
and im not doing it again, can't hold my self i don't care gas is cheap here
it's exactly 3x in Istanbul
BUT!!!!!!!
when you drive hard in city with SRI while it's crazy hot outside, then god bless your mpg
MPG will drop way more than stock intake
if you drive normal, it will be same as stock intake
the cold air that comes to it will be enough for the throotle
that's why I got 19 or 20 in city
in highway, no problem
Give some comments people, i totaly forgot the stock intake
is that 2500 rpm 4th gear slow?
any videos of stock?
And Bostonsilver, I still couldn't go to that custom metal shop. Friday is the only day and missed it last week. So will definitely try tomorrow.
Takeoff before I filled the tank on that morning...like 7am
Stayed at parents
Dist 280 miles
13.9 to be exact
Day time, 85+F
no wot wot
no exhaust sound
no vtec
no intake
BUT!!!!!!!
#75
and i just wanted to know if you were easy on the pedal or, all the way low....
another reason I gutted my car is coz i felt pretty powerless in 4th and 5th....
#76
also....you should get more gas mileage if you coast and go easy on the pedal....highways i get 34MPG...mixed i get 26-27MPG and all city i get 20-22MPG....
i think city driving is mostly about coasting....going easy into the throttle....shifting early (2000-2200 rpm)....
#77
okey, I will test it again, im positive, straight road and floored it but still...
also I'll do one during the day
yeah pedal at the lowest
not easy on the pedal
to be honest i love flooring it at 4th gear at 75mph
the car does make you feel the torque and im not sure where the rpm is during 4th gear at 75mph but stage 2 exhaust does sound sexy with SRI and luuuuve hearing it
#78
To be honest if that is faster then most tl's out there then im very suprised. I always complained about my car being torqueless and tought I had a problem but from what i see here I guess was wrong.
Im not gonna say anything as a fact but i think my Tl picks up speed in fourth eaiser with the stock intake... I do have HFC_V3JPipe_comptech exhaust tough.
You guys can say what ever you want but i when i removed my K&N Intake and put the stock intake back in, I felt that the the low end improved very much so...
#80
Which SRI or CAI K&N, which one were you using?
As I mentioned before in my progress thread, we installed K&N CAI to friends 08 Type-S, my low end power was much more, after feeling that, I never installed CAI to my car.
That was the main reason, other wise I would've deifnitely try my K&N as a CAI to see what it's like
