AEM v1 hoses question
I recently purchased a used AEM v1 intake and found out that it was missing the two hoses for my intake and also the rubber vibration mounts. I know i can probably pick up the hoses at a home depot and the vibration mounts at a auto-zone but can anyone tell me the sizes that it has to be? i know if i dont switch out any of the piping and left the oem one's there it wouldn't function at maximum capacity.
(yes i tried using the search button and could not find anything)
thanks in advance AZ
yeah same thing happen to me. The vibration mount you can get a 6mm 1 1/2in machine screw, a 6m Hex nut, and a washer. After that you can go to your resonator and take off the rubber dampener.
For the hose just go to auto zone. Get 2 ft of 1/2in and 1 ft 5/16 hose.
Everything should amount to less then 10 bucks. I got all that stuff for 5.50. The reason being was I did the coolant bypass a while back so I just rewired all the tubing. all I can say is A+. Also keep some coolant handy. There is a small pool under my car from removing those lines.
navtool.com
31
Nov 16, 2015 08:30 PM
detailersdomain
Wash & Wax
Oct 9, 2015 10:13 PM
navtool.com
Sep 25, 2015 05:15 PM
