Aem Cai
Old 08-03-2008 | 01:05 PM
amk6453's Avatar
08 TL Type S
Aem Cai
hi guys,
i'm the new owner of 08 TL Type S, and i just ordered a AEM CAI, but i'm wondering if i need to get the by-pass also? and is it hard to install it by myself? do i have to take off the front bumper?
Old 08-03-2008 | 02:40 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
bypass valve does not come in 3.25" which is the diameter of the cai tube... also it will not work, some have reported that the car can suck in the foam and cause harm to the motor.... also the bypass valve disrupts the flow of air into the motor
Old 08-03-2008 | 05:27 PM
20TL05's Avatar
8th Gear
bypass valve robs engine of flow...just use common sense. On my 03, I had the two piece kit from Injen...so in the spring/summer I would convert to CAI and in the rainy fall/winter to SRI.
granted i became lazy after a couple years and decided to keep it SRI. :P
Old 08-03-2008 | 05:48 PM
Excelerate's Avatar
Former Sponsor
Exactly.
We never recommend the bypass valve even if it's available. It's not a good product. It does prevent sucking up water but in order to suck up water you would have to drive through 2-3 ft of standing water. You have to submerge the filter and therefore the bumper to suck up water. If that's the case then don't even bother buying a CAI. The bypass valve requires you to cut the tube; therefore, it disrupts air flow. And they fall apart. As stillhere said too they don't come in 3.25" diameters either.
Old 08-03-2008 | 07:26 PM
amk6453's Avatar
08 TL Type S
ic... thanks for the info guys!
how about the installation? is it hard? do i need to remove the bumper?
Old 08-03-2008 | 10:01 PM
anx1300c's Avatar
You don't HAVE to, but it makes it much easier. 10 minute job to remove. Do a search; there are instructional videos on here somewhere.
lanechanger
10-13-2015 10:56 AM
swany0095
2G TSX Performance Parts & Modifications
10-07-2015 02:18 PM
h22lude
09-27-2015 06:22 PM
kingbharj
09-25-2015 07:25 PM
Quick Reply: Aem Cai
