6mt perfomance upgrades
I need to rebuild my transmission so im looking for stronger parts and what i can do for gearing. I plan on charging my 3.2 motor with the gerzy bear rotrex 2.0 charger so any tips on where to find the parts and what is best for this would be greatly appreciated.
So the reason I am looking into rebuilding is because it doesnt want to go into gear very well when I am slamming gears and occasionally when i am just cruising. But I was also woundering if there where any gear replacements that would help me down the strip and i figured lets just build the tranny to make it last almost forever if possible. In the long future as my kids grow up i do plan on having a newer type s and this car will be a track car for my kids when they are old enough so by the time they will be driving this car i would like to have 600+ hp.
Also either way im still curious if there is anything out ther I have had trouble finding anything. I would atleast like to replace my syncro rings and such do to the resistance I do get occasionally to shift into 3rd and 2nd. And while im in there see if i can find different gears for better track performance.
The transmissions in these cars have a well known and documented issue with third gear; fortunately there is a very easy fix, simply drain the MTF out of the transmission and replace it with 2.3 quarts of ACDelco Synchromesh Friction Modified (the "Friction Modified" bit is very important, they also sell the same stuff without that designation). My car, and many others as well on this forum have experienced the same thing as you, and as soon as the Synchromesh is put into the transmission, bingo, problem solved.
Thank you horseshoez I will give it a shot. I know when I first got the car it was worse and I did try penzoil syncromesh which did help alittle. But for the future what do you think about changing the gearing for racing. Is there like better gearing so i can get better track times?
https://www.powerrevracing.com/P2R-J...ive-p/p355.htm
The part number for the fuid is 89900399 sold under AC Delco, its GM scyncromesh friction modified. I am running my stock gear box above 600 WHP , but am gentle on the transmission in terms of shifting. There is no real reason to slam gears with this kind of power, the frame will begin to bend if you are able to get traction on slicks and the engine is easily capable of spinning the tires up until 100+ MPH on toque alone. I have slight dimples on the front fenders from hard pulls on drag radials. As far as beefing up the trans there is not much you can do, I know some member had straight cut gears. Not sure if it's worth it, the gears were made for use in the Honda Odessy turbo that Honda was using for a hill climb race car. You shouldn't be able to get that kind of load on the gears in a TL unless you are slamming gears and with weight transfer in a FWD car it just doesn't make much sense.
Did you use ACDelco Synchromesh or ACDelco Synchromesh Friction Modified? There is a HUGE difference between the two.
Keep us posted.
Clutch kits 6spd type s 08
In the market for a clutch kit and want to do this right ,as of course starting with the transmission is probably the best place to start off with My project. Need a kit that will retain stock feel with would be ideal ,and handling of 500-600 hp
any thoughts greatly appreciate
Definitely not a stock feel
If you are looking for a setup that will take 500hp we do have our XLR8 Drag Clutch Kit available. You can find it and some additional info on our website here. If you have any questions on the kit or would like a shipping quote please feel free to send me a PM or shoot us an email. With the increased capacity does come a more aggressive pedal feel, but this is something that should be consistent with most other kits on the market!
We will also be offering 10% off our XLR8 products for Black Friday starting from 11/20/18 and running until 11/26/18 so don't forget to check out our website!
Happy modding!
Sorry, this is going to be a case of you cannot have your cake and eat it too. You are going to have to choose between stock feel and clutch system being able to handle your lofty goal of 500+ hp.
How much torque do you think you will make?
My end goal is 500-600 hp torque not so sure but guess would be 400+
Ment to ask how was the installation end to end
Did you have any help with it
I did have help for the bigger items and guiding things in and out but you can do it on your own.
Here's my install thread and review:
https://acurazine.com/forums/3g-tl-p...nstall-939621/
NOVAwhiteTypeS
Jan 22, 2003 04:22 PM
