3G TL Custom Aluminum Radiator Project
Here is a few preview pictures of the 3G TL radiator that we have done down at the shop ready for install tomorrow morning. This is the first one for prototype testing. The core is MUCH larger than stock...will hold more fluid as a whole...and should perform superior to the stock unit. Not to mention the bling factor.....looks good!
Originally Posted by lookinco
wow it sure looks good. So what can we gain from this?
Mikey
8 second & 150 mph member
That there my friend is some coin, looks smokin!!! My griffin is that size in my race car and that keeps temps uder 170 in 100 degree days. Oh yeah it make 900 hp on n20 Great to see it coming through for you mikey. Your motors gonna look hot even without a s/c, but..... if you polished one up and put it on there... HAHAHA
Do you plan on running the fans off of a fan controller or from the factory relays? You are putting a lower t-stat in also correct? By increasing the capacity of the cooling system all your doing is prolonging the time it takes to come to operating temperature. Operating temperature is determined by the t-stat opening and closing allowing the radiator to cool the warmer coolant from the engine, so if the cooling fans are still coming on as intended by the factory then you will still run the same temps. Also dont bother looking at the factory temp gauge as it only has three reading on it, cold, operating temp, and hot. There is no inbetween on the gauge regardless of temps.
Originally Posted by Excelerate
Hey Mike, is the radiator wider than the stock radiator? You said it is larger. If you are planning on going S/C it can't be wider as you won't have enough room to fit the upper coolant hose due to restricted space with the blower.
Ok...its now installed and I have picked up the car for initial road testing. So far so good. As for some answers to the questions....lighter weight....nope....there is more to this unit. The stock unit has small plastic jugs and epoxied aluminum fin sections, this has dual core full aluminum cores with much larger aluminum jugs that are NOT cheaply epoxied. Yes...we are currently running on factory relays with dual high performance fans. Basically...what we can hope to gain here is more efficient cooling traits. As the supercharger suffers from heat sync probs and due to the location of the rad hoses...we suffer great heat buildup as a whole. This greater capacity should increase the cooling traits of the motor as a whole as well as the HP fans pull WAY MORE air though the rad unit than OEM stock fans do. There are more fan blades in the fan and it is HP fan units also that are faster....therefore....it will cool the water in the radiator more efficiently and faster....meaning you should be exchanging COOLER water as a whole into the motor when the thermostat opens up. On very hot days or very hot conditions when the thermostat opens up and stays open....then this unit will really perform as with a dual core full aluminum unit, its going to be FAR more efficient.
As far as fan relays: Yes....this can be adapted to a manual fan switch fairly easy so you could in effect...run the fans all the time if thats what you wanted to do. Thats not a big deal at all. You would then be in control of when the fans come on if thats what you wanted to do. Or another relay could also be installed to make it trip earlier...thats possible too if thats what you wanted to do. Right now...I am just running off factory relays though and factory thermostat....but I will change out the thermostat myself later at home, which will in effect...lower the operating temp as a whole with a more efficient rad unit...which should be good all around. Bling factor is good too...looks very nice in there. We are going to look into a supercharger application too...one totally different. We will relocate the upper hose altogether to the other side of the rad (passenger side) which will even make the rad even more efficient and get rid of that pesky hose problem at the top hose with the supercharger. That just cant be good to have that hose so close to the supercharger unit. Move it to the passenger side...we are all set! No more hose problem and better cooling to boot!
Originally Posted by dan.....k
What can we expect as far as price?
Originally Posted by SIK TL
Dude where do you work? Carbon fiber engine covers...aluminum radiators...what next polyuerathane (s/c) body kits. Nice to see you are step ahead for the 3G's...it is appreciated.
Ryan Christopher
Hey Mike, You might want to look into adding the Spoon Radiator cap and a new T-stat. Also add the mugen fan switch. It will help to keep it super cool with that new radiator.
Its look good, and keep up the good work.
Jason
Jason
Jason
Jason
Originally Posted by CleanCL
he should flip the spout so the overflow line is facing the overflow tank, all that work and it just looks kinda ghetto like that lol.
You know what....your right! That one inch of hose looks so ghetto....I should have never done this project and should remove this thing right now...Shame on me for trying to develop new parts...!
One on the right for me
^-You dont have to take everything personally. I'm sure most members appreciate your efforts. While I would have phrased the critique a little more eloquently the poster makes a good point - it would look better flipped around.
The Boss
Originally Posted by MichaelBenz
All in good time my friend!
Originally Posted by Meek32v6
preparation and planning
Originally Posted by AcuraDriver2006
Very nice Michael. I wonder if that radiator will fit on a S/C TL due to blower being right there..........
Specs have already been changed for that. I just thought to call it ghetto was a bit incorrect/overly strong. Is it perfect the first time out....nope...but not far off from what we were looking for!
From past experience I know nothing is right the first time out. Glad it that was identified for the second draft. The radiator looks awesome. Keep up the good work.
if anyone can appreciate this post it's me, and i don't even have a TL, i was just joking and expected you to say the final production would be flipped. if you saw my car and the things done to it underneath, you might laugh. i don't always have the professional answer, but the 'get it done' answer. well, enjoy, and hope to see more custom products.
05 TL
I think that it looks good facing the wrong way. It goes around and ends up in the same place. With the cover on it looks great.
Props for doing something new and paying the $$$ to get it done right.
Originally Posted by banelba
So anyone saling his old radiator
