300+ horsepower
I have and 06 TL that I bought a couple of months ago. I love it but really need it to have more speed and power. The car looks to good for it to not have 300+ horses but I am not sure how to get this reliably. I am looking for some direction on reliable mods for break the 300 horsepower mark. The goal is 350 but I am not looking to spend time in the mechanics shop all the time after the fact. The car is my daily dirver as I like driving the car.
307whp
240wht
(Would be awesome to see 275ish...)
https://acurazine.com/forums/members/michaelbenz-176393/
240wht
(Would be awesome to see 275ish...)https://acurazine.com/forums/members/michaelbenz-176393/
Originally Posted by jayunsplanet
307whp
240wht
240wht
More power is always a desirable thing for any gearhead. But do keep in mind that the TL is a FWD platform and as everyone knows, front drive cars have very poor traction. So unless you're planning on setting the car up for drag racing, street tires just ain't gonna get it.
You need a Comptech Supercharger. I'm not sure if there are any left, as Comptech is in the process of closing its doors. I have had my supercharger for over a year now. It is very reliable. With the addition of the procats, I am at 316 WHP and 264 FT/LBS. It makes the car so much fun to drive.
That's respectable. Interesting that you are making a little more whp and more torque than MichaelBenz, who has similar mods. We really need to close the distance between HP & torque in these Honda/Acuras.
Originally Posted by speedbawlinTL
whp- wheel horsepower (what your car puts to the street, not at the crank)
ft/lbs- foot-pounds of torque (ft/lbs. are how it's measured)
fwd- front wheel drive
welcome to the forum
Tim,
the pro cats replaces all 3 cats to high flow cats. Its best to put it in before the supercharger. If you decide to ever install the pro cats you must remove the supercharger to install the front cat.
You will gain 15-20hp n/a or with a super.
Cost is about $1175 shipped from a vendor.
Check the group buy section.
Former Sponsor
If you're just looking for 300 crank hp (you have 258 from the factory) get an AEM Cold Air Intake, E Shift Pro Cats, Exhaust (I'll be making one shortly), Unorthodox Racing Crank Pulley, Thermoblock Spacers. You will be over 300 crank hp with that.
Man SWEEET
. I cannot have an Infiniti pull ahead. A lexus ok Maybe but forget it an Infiniti!!!
whats the thermoblock spacers and what do they do?
use the search button
www.outlawengineering.com
all the info you need is there... they're really easy to install and for $100, it's not too bad
307whp
240wht
240wht
thanks for that link
Originally Posted by mmcv6
Tim,
I'm not sure about the 3G TLs but on the 7G V6 Accords this 3rd cat is easily replaced with a high flow cat or race pipe as there is no 02 sensor in this location.
Now, there is a problem. It seems to me that there are not aftermarket camshafts for 3.2 l TL engine. It should have lower lift cams same as OEM and high lift cams that would allow engine to breed up to at least 8000 RPM (longer lift). Valve springs should be a bit harder in order to insure that rockers follow cams at high RPM. Underdrive pulley would be a good prevention.
Engine like this would be very similar to original for day to day driving (up to 4500 RPM). That goes for FWD traction problems too. Pushing it to higher RPM would release more power for longer time. More than enough to overtake most of them.
Of course there is reliability issue. If you push it all the times it would not last as long as factory engine, but that goes for all power improvements.
Honda already made similar engine. 2 l 240 HP Spider makes 120 HP/l. 3.2 l TL engine with 350 HP would have “only” 110 HP/l. Piece of cake.
^It's all about perspective. I think its worth every penny. 60+ is not a minimal gain to me.
its just not worth it to me.
Neither are the cats...
word.
How much do the procats run for? Is that the same thing as a catback? What exactly do they do? I've got the AEM CAI installed, and that was quite possibly the best buy I will ever make for my ride. I plan on getting the thermoblok spacers and the underdrive pulley installed next. Or should I buy a rear sway bar next? Hmm.
Peace
Peace
"to go fast in this car is steep."
^^ very well said man.. it's not cheap to fix up the TL..
Everytime when my cuzzins mods his RSX.. i ask him how much it was.. he said about couple hundred... for the same part, but for the TL.. it's much more expensive.. like the exhaust.. comptech has one for us but about 1g+,, while his rsx can get one for 600. On top of that the TL has MUCH less options when compared to other sports cars like the RSX..
and "How much do the procats run for?"
They run for about.. 1g+ but i think they give u about a 20hp and a good amount of torque.. they are high flow cats and you can purchase them from excelerate.. and as for what mod you should get next... it's either u want to make your TL a handling car or a GO car.. if u want speed, go for the UR pulley and thermoblock spacers.. if u want your car to straght handling, i'd go with sum coilovers and the swaybar.
Originally Posted by STANGMMX
Thanks for the advice. How much of a difference does the sway bar make? and the coilovers?
http://gprime.net/flash.php/postingandyou
just messin with ya man! that one hasnt been seen in a LONG time! lol.
Sway bar....high recommends. Cheap and a must have...nuff said!
Sep 25, 2015 06:14 PM
Sep 14, 2015 10:48 AM
