25 hp
Old Nov 11, 2012 | 07:34 PM
Bobby Digital's Avatar
25 hp
I know the normal CAI and exhaust mods will work but what is the best way to get an additional 25hp out of the base 3G?
Old Nov 11, 2012 | 07:39 PM
Bearcat94's Avatar
AZ Community Team
Pre-cat deletes, j-pipe and exhaust.
AFAIK, that's about the ONLY way to get 25 WHP without FI.
Edit:
Except maybe losing weight. Losing weight is the equivelant of gaining HP.
Old Nov 11, 2012 | 07:48 PM
Please gently explain pre-cat deletes
Old Nov 11, 2012 | 08:17 PM
Joneill44's Avatar
https://acurazine.com/forums/3g-tl-performance-parts-modifications-112/introducing-rv6-v3-precat-deletes-taking-deposits-799908/
Old Nov 12, 2012 | 09:23 AM
bouncer07's Avatar
Some easy gains can be driver's mod, lose some wieght can make the car faster (if you're over weight). Also, kill the spares and other plastics in the car that'll also kill 500 lbs off the car.
Old Nov 12, 2012 | 11:34 PM
Bruce Banner's Avatar
I would think you need metal parts, more than plastics to get up to 500lbs.
Old Nov 13, 2012 | 09:06 AM
losiglow's Avatar
^ There isn't too much steel that can be dropped. Front and rear bumpers is an option (35lbs total). Just don't rear end someone or you can say goodbye to your radiator. It makes you a more cautious driver though.
Mid muffler is another option. About 9lbs. there. Lightweight pully is about 9lbs too. Lightweight wheels can be massive if taking into account dynamic weight.
Old Nov 13, 2012 | 03:38 PM
pmak23's Avatar
port and polish intake manifold and intake runners best bang for your buck, 300$ and somewhere in the 25-35 hp range gain.
Old Nov 13, 2012 | 07:20 PM
anx1300c's Avatar
Old Nov 13, 2012 | 08:55 PM
Otacon's Avatar
flappy paddles
Edit:
That or FI.
Old Nov 13, 2012 | 09:08 PM
anx1300c's Avatar
Edit:
There are other ways to make power N/A if you have the means. 3.7 manifold/TB swap, cai, pulley, lighter wheels, Bisi cams, JnR ecu if you're very daring.
Old Nov 13, 2012 | 10:00 PM
Sonnick's Avatar
All motor
Just port your runners. Apparently there have been reports of 45-50hp gains from the runners alone.
But seriously, intake/full exhaust is a great place to start if you're willing to spend the money.
Old Nov 13, 2012 | 11:27 PM
lilsid112's Avatar
I also agree on starting out with intake and exhaust.
Richie v6's Avatar
Former Sponsor
Originally Posted by Richie v6
Here is a quick RV6 crash course, this is rough draft that will eventually be added to the webpage. You can get more details on the rv6 website www.rv6-p.com
The order of exhaust components.
Heads (engine) > precats > Jpipe > 3rd cat > exhaust
Jpipe+3rd cat delete
The RV6 V3 jpipe is our latest design and has the best gains due to its 2.25" long runner design. It replaces both the factory jpipe and 3rd cat in one piece. No check engine lights are triggered since there are no sensors on the 3rd cat. It is recommended that you get the jpipe before PCDs or HFPCs.
Pros:
Good mid and high range gains
Replaces factory jpipe and 3rd cat in open piece
Bolts up no modifications needed
No obvious place for a 3rd cat.
Cons:
May not pass visual inspection in some states.
Precats
There are current 2 RV6 options for a precat replacement. These options are effective because Honda used a very restrictive precat design. They are made with stamped sheet metal to reduce cost and have a small 1.75" out.
Precat deletes or PCDs replace the factory precats with a straight pipe using smooth flowing castings a 2.25” outlet. Precat deletes include special adapters for the O2 sensors and do not throw a check engine light.
Pros:
Maximum performance gains
Low cost compared HFPCs
Cons:
Raspy exhaust
Exhaust smell
Requires an extra resonator for rasp free operation
High flow precats or HFPCs replaces the factory precats with high flow catalytic converters. They offer the best of compromise between performance and daily drivability. They are also paired with our smooth flowing castings 2.25” castings.
Pros:
No rasp
No exhaust smell
May pass visual inspection
Cons:
More expensive then PCDs
Slightly less power gains compared to PCDs
Feel free to contact me with questions.
Old Nov 14, 2012 | 10:38 AM
UA6's Avatar
UA6
Why is 25HP the magic number? Are you trying to travel to 1985 or something?
Old Nov 14, 2012 | 10:43 AM
it just aint a car, its my time machine.
(only applies to old school cars)
Old Nov 14, 2012 | 10:47 AM
AccordFlex's Avatar
Decal, decals and more decals
Old Nov 14, 2012 | 10:50 AM
SharksBreath's Avatar
BANNED
somebody say decals?
Old Nov 14, 2012 | 11:51 AM
losiglow's Avatar
Fire extinguisher and a roll cage.
Old Nov 15, 2012 | 11:33 PM
LOL, I'd to see somebody roll with no bumpers and not get pulled. :p
Old Nov 16, 2012 | 10:07 AM
Excelerate's Avatar
Former Sponsor
XLR8 V2 J-pipe and CAI = 25 hp
Old Nov 16, 2012 | 10:21 AM
350's Avatar
350
My first ricer
Do you have a dyno of that? And I'm assuming at the flywheel.
Old Nov 16, 2012 | 11:42 AM
Mrtastygoody's Avatar
Level: Noob
Amazon Amazon
These should net you at LEAST a good 75 rwhp.
Old Nov 16, 2012 | 12:46 PM
losiglow's Avatar
Here:
https://acurazine.com/forums/showpos...2&postcount=61
You keep the bumper panel on. Otherwise it'd just look
