2008 TL-S engine swap to base TL?
I’ve seen tons of threads about Type-S engines into a UA6, but none about a base UA7. Will it be cheaper to modify the existing engine?
I will be doing all my own labor
Engine only or do you plan on the transmission as well?
UA7 is the type s 07-08. But the type s 3.5 will drop right into an 07-08 base (UA6) TL. The 05-08 RL 3.5 will also fit as its pretty much identical to the type s 3.5 and can be found much cheaper as some places don't know its the same motor. the 07-09 MDX J37a1 will also drop right into an 07-08 TL base or type s. if you're an 04-06, things start getting a little more complicated and more research would need to be done to fit larger displacement motors.
Latent car nut
Received 2,013 Likes
For the older 2004-2006 cars with a 6MT, my understanding is the swap can be performed by simply swapping the bellhousing on the transmission and then swapping some sensors. That said, while the J35A8 would be a very desirable swap from my perspective, you couldn't pay me to drop in a J37 of any stripe given the horrible oil consumption issues many of them have.
Latent car nut
you are correct. just swapping bell housing would do. and that generation J37 does not suffer from oil issues. the j37a1 from the 07-09 mdx is similar to our j32a3 and j35a8 just being a 3.7L. not all of it is the same but it does not have that special cylinder liner coating and piston rings that cause the oil burning issue.
there are 2 j37a1s. the 07-09 and then 10+ mdx. the 10+ mdx j37a1 (gen 2) is very different despite the same engine code. I believe that was the first j37 honda decided to try out the new stuff
Latent car nut
I'll say it differently this time; I have heard lots of theories regarding which, if any, J37s do not have oil control problems. So far I have yet to see any evidence to support any of them being immune to the issue; quite to the contrary actually.
Acura Tech Line Summary Article
July 2016 BTS 160705 Version 1
Engine Oil Consumption
AFFECTED VEHICLES
2010−13 MDX, 2011−12 RL, 2010−14 TL, and 2010−13 ZDX
Latent car nut
I do not believe there is any such thing as a "Standard J37"; just because Honda doesn't cover those in the Tech Line article in no way means the earlier J37s don't have issues. Said another way, I've heard of any number of pre-2010 MDXs with oil issues. Long story short, you couldn't pay me to put one in my car.
UnSpell (08-01-2024)
Cbronze_06TL
38
05-26-2012 07:57 PM
