2005 Acura TL AUTOMATIC performance
Hey guys.
So big question. I'm new to the Acura community. My friend has given me his 2005 acura tl. He took real good care of it. 140,000 miles and runs absolutely great!
I don't want to race the car but would love to add some performance parts on this vehicle. Asking everyones opinion please. I want to add some horsepower to it, make it sound nice and still be able to pass inspection. Thank you everyone.
Hey, I too have an automatic (2006 Acura TL base w/ navi). Here are my plans I've laid out for the car including what has already been done. In your case, if you just want a little oomph and some nice sound, start with a cold air intake from AEM and the ATLP V2 j-pipe and stay away from short ram intakes. They sound good but you're actually working backwards technically speaking because they suck in hot underhood air. I will have it be known that taking out the stock airbox is going to be a royal pain in the ass unless you remove your front bumper. I didn't remove my bumper but had to use a hacksaw to cut the stock one into separate pieces so that I could eventually pull it out. Anyways, here's my list:
Current mods + other things
Engine:
AEM Cold Air Intake - done
ATLP V2 J-Pipe - done
ATLP Hi-Flow Cat - done
XLR8 Base Duals - done
P2R Throttle Body Spacer - done
RV6 Hi-Flow PreCat x2 - done
UR Crank Pulley - pending
UR Tensioner Pulley - pending
Throttle Body Coolant Bypass - pending
J37 Intake Manifold - pending
J37 Throttle Body - pending
J37 Throttle Body Spacer - pending
Handling:
BFGoodrich GForce Comp2 A/S Tires - done
Tein Street Advance Coilovers - pending
Trunk brace -pending
Stiffer/Lighter Front Sway Bar - pending
PG Racing Rear Sway Bar - pending
Brembo/Stoptech/Powerstop front rotors - pending
Aesthetics:
Type-S Headlights - pending
Type-S Gas/Brake Pedals - pending
Trunk Lip Spoiler - pending
Carbon Fiber Hood - pending
Rear Window Visor - pending
Shark Mouth Grille - pending
Spray Paint Strut Tower Brace - pending
Full Debadging - pending
Window Tint - pending
Entertainment:
Bluetooth Audio Dongle - done
Auxiliary Input Box - done
Weight Reduction:
Hood Insulation Delete (1.8lbs)- done
Weather Strip (above hood) Delete (??lbs) - pending
Engine Bay Covers Delete (6lbs) - done
Spare Tire Delete (34lbs) - done
Rear Seat Arm Rest Delete (6lbs) - pending
Rear Floor Mats (6lbs) - pending
Braille Battery (27lbs) - pending
Trunk Insulation Delete (23lbs) - pending
Total Weight Savings Once Complete - 108lbs
Misc:
Motul Antifreeze Additive - pending
Navi System Hack (DumpNavi) - pending
Engine:
Handling:
Aesthetics:
Entertainment:
Weight Reduction:
Misc:
EvilVirus (01-16-2016)
No problem man, it seems like when I'm pressed to get information on my car, it falls on deaf ears until after the fact so I try to stand out from the norm and provide newcomers with as much information as possible so that the question asking is at a bare minimum. Good luck with the new ride and if you have any more questions just PM me!
Engine:
Handling:
Aesthetics:
Entertainment:
Weight Reduction:
Misc:
Engine:
Handling:
Aesthetics:
Entertainment:
Weight Reduction:
Misc:
On the flip side, be careful with aftermarket parts such as rotors. I had some that were heavier than stock, but my current ones are about the same weight as OEM. Keep an eye on tire weight too. Stay away from Bridgestones; they're always porky. Coilovers/aftermarket shock and spring combos usually save a few pounds as well.
Don't forget you've also saved a lot of weight from the intake and exhaust mods, pulley etc. The 3.7 setup also knocks off a little weight.
This is the most comprehensive list you're going to find.
https://acurazine.com/forums/perform...st-1-a-610974/
I haven't weighed my car, but considering stock is 3482 for a manual w/o navigation, I'm right around 3300 even.
UCLAs2k
05-04-2016 09:33 PM
