'07 Tls Cai Install ! ! !
Old Jun 28, 2008 | 01:55 AM
EcKoHeD72's Avatar
Scuba_Steve
Whats up guys? To do the CAI on an '07 TLS, i've read that u have to take the bumper off. Is it possible to gain enough access to do the install by just pullin the driver side wheel?
Old Jun 28, 2008 | 03:23 AM
JsL138's Avatar
Yes, you have enough access to the resonator by just pulling the driver side wheel.
Old Jun 28, 2008 | 07:41 AM
kipros's Avatar
spend ten minutes to remove the bumper..it will make the installation so much easier...
Old Jun 28, 2008 | 08:57 AM
JVs_TypeS's Avatar
lil' kid in ya....
Remove the bumper!!
I HIGHLY recommend you remove the bumper to do this installation. I did my TypeS and there was actually a couple of steps left out of the instruction video floating around the forums....removing the OEM intake is not as easy as you think.
Reasons why you need bumper removed:
- not that much room to work from just inside the wheel well.
- intake tube has a bolt underneath the battery that is very tricky to get to and can only be reached from underneath.
- resonator box has 2 rivets that must be drilled out..and can only be reached from the front of the vehicle.
- depending on what CAI you get you may have to play around with the fitment of the filter and the mounting bracket so the fog light will not rub against the filter (see my other post). AEM CAI might not have a clearance issue with fog light.
- even with all the bolts/screws/rivets removed, you still need to apply a bit of force from different angles to jank the tubing out.
- REMOVING THE BUMPER IS A 15 MINUTE JOB...I actually got it down to less then 10 minutes after removing it a few times to work the INJEN CAIN fitment issue.
Good luck!!
Old Jun 28, 2008 | 09:36 AM
Mike 06 TL's Avatar
'06 6MT WDP
^ditto
It's a no brainer. Remove the bumper.
Old Jun 28, 2008 | 10:00 PM
flydog's Avatar
Another stupid "should I remove the bumper" thread. Try using search next time. This question has only been answered 300 times in the past month.
Old Jun 28, 2008 | 10:20 PM
JVs_TypeS's Avatar
lil' kid in ya....
Give the OP a break! There are so much info floating around and it may take some peeps a while to find/operate the search link. We Acuraziners are a civilized group so let's welcome and offer our assistance to our new members....including myself.
Old Jun 29, 2008 | 12:47 AM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
if you dont remove the bumper you have to pretty much rip stuff apart...
giovane
2G RDX DIY & FAQ
Jul 8, 2016 10:46 PM
njresendez
3G TL Photograph Gallery
Sep 21, 2015 06:32 PM
2G-TL-Type-S-03
Sep 20, 2015 12:48 AM
TxRzrBk
Sep 17, 2015 01:07 PM
DDTsx06
Sep 8, 2015 06:56 PM
