'04 Accord HFC Cat on 3G TL???
I thought I read most of the exhaust parts between the two are interchangeable and thought the 3rd cat was one of the components. Anyone have additional insight or done the swap?
I checked part numbers from heel toe and they are different.
you could also get on a honda forum and ask what their specs are if the vendor doesn't have them, but he should
I can confirm this for you.
I had a 2005 V6 6MT Accord coupe which was totaled by a deer. I purchased the car back from insurance and parted it out, however I kept the PCDs and Jpipe and swapped them over to my 2007 TL-S 6MT.
So yes, you can swap these out and they are interchangeable. I am using RV6, so if they are from a different company, might want to verify first, but im almost positive they will fit regardless.
Also recommend getting new gaskets if you are using an old set.
Former Sponsor
04-08 TL and 03-07 Accord V6 uses the same rear cats and the Pre-cats are also the same.
http://store.excelerateperformance.c.../i-285244.aspx
emailnatec
29
09-28-2018 04:27 PM
adreano17
09-29-2015 08:48 AM
