Yes, '07-'08 Amplifiers are interchangable
Old 10-19-2016, 08:46 PM
jehuh's Avatar
Hello All,
I asked a question on here a long time ago about the replacing my defective amplifier in my 2004 TL with an amp from an 07-08 TL. No one seemed to have an answer so I went ahead and bit the bullet and bought one off of ebay for about $90.00. I am here to say that YES the newer amp will work perfectly with older TL's. It isn't worth it to replace your 2004-06 amp with one from those years because it will eventually fail. I spend a lot of time in my car and a good audio system is a must so I am completely satisfied. Hopefully this helps early 3G owners who experience the common amp failure and don't wish to solder things back together.
Jackass (10-20-2016)
Old 11-16-2018, 10:37 PM
Jackass's Avatar
Finally got around to doing this. Swapped my A01 amp in my '05 with an A11 amp from an '07 I bought off of ebay. I now have a functional sub and front speakers that aren't at half volume and/or buzzing constantly.
Old 11-17-2018, 04:16 PM
A-SPEC TL
Klutch's Avatar
i got a 05 and got lots of buzzing noise from the speakers when the car is on. if i key off to ACC position the buzzing will stop after like 5 secs? speakers and everything still work fine. do you think the amp is the culprit? wondering why the buzzing goes away when i key to acc position.
