XM radio question
Old Oct 28, 2005 | 03:09 PM
jbcritch's Avatar
Question XM radio question
OK, I did a search and found where one member attempted to address this question, but wanted verificaiton from others, and got none...
what I am trying to find out is what the "catagory" and "channel" buttons on the XM radio do....I have not discovered a difference yet.....
sorry if it is a stupid noob question...but I am a noob owner.....
Old Oct 28, 2005 | 04:39 PM
Hawhyen51's Avatar
XM radio programs are divided into a number of distinct catagories i.e. Country, Hits, Urban, Classical and so on. So when the category buttons are pressed it will take you from one to the other and access all the channels within that particular group. Does that make any sense? Here is a link to the XM Channel Listings and look at the 3rd column. In channel mode you can select all available channels.
Old Oct 28, 2005 | 05:06 PM
acuraTL44's Avatar
Let me see if I can clarify that a little.
Now, when you are in "Category" mode, turning the channel nob will only scroll through the channels in that spacific category, as stated above. When you are in "Channel"(Ch) mode, you will be able to scroll through all of the channels.
Old Oct 29, 2005 | 10:25 AM
Hawhyen51's Avatar
Yes, and the one thing I didn't check was what happens when all the channels in the category have been scrolled through. But that's the difference between "Category" and "Channel" mode.
Old Oct 31, 2005 | 07:15 AM
jbcritch's Avatar
makes sense...thanks!
Old Feb 27, 2006 | 02:52 PM
zafer's Avatar
Question
My 'category' buttons don't jump to the first channel in each group as I would expect them to. Is this normal?
Puma Jim
20
Oct 20, 2016 11:59 AM
BoricuaTL
Apr 8, 2016 01:08 PM
06TLMatt
Oct 2, 2015 08:14 PM
tmux
Sep 21, 2015 05:11 PM
datadr
Sep 12, 2015 09:12 PM
