Would the Infinity 6.5 inch speakers fit the door and rear deck?
Hello. I`ve read that the TL has 6.25 inch speakers for the front and rear. I searched a couple websites and it states that the Infinity Reference 6032si 6.5-Inch would fit. I don`t know if this is true. Here is the link below. If someone can confirm this it would be much appreciated! Thank you.
Infinity Reference 6032si 6.5-Inch, Shallow Mount High Performance 180-Watt Two-Way Loudspeaker (Pair)
The TL uses 6.5s all around but no coaxials in the rear.
I wouldn't upgrade the rears and I definitely wouldn't stick Infinities in there. Stock will sound better. Take it from someone that has done Infinity before, get something else. Just about anything on the market is better.
I went with all Memphis M-Class . Syncronus 6.5" comps up front and 6.5 co-ax in the rear. Used he stock amp and added a JL Audio 10w3V3 sub all sounds good to me , although im considering amping my fronts now . You guys weren't joking about doing more with the audio upgrades ! Its a bug for sure !
sockr1
10-01-2015 01:31 AM
