Hi RonA, I am getting ready to do a Timing belt change on my 2006 TL, planning to do the start bump method to remove the pulley, would greatly benefit from having a fuse diagram so i know how to pull the fuel injector fuse.
Can I please trouble you to send my the fuse panel wiring diagram to poony69@hotmail.com?
I apologize for my potentially stupid follow-on question, however, I am not 100% sure which fuse(s) to pull in order to do the bump for the crank pulley removal.
Would it be both Fuse 2 in under the hood as well as Fuse 19 under the dash? The other forums mentioned the fuel injector fuse, I am not technical enough to know exactly which fuse(s) associate with this.
New Request (please!): wiring diagrams for the Navi DVD drive. I bought a pdf of the service manual, but it's oddly missing 22: 426-453. I think I just need 22-453, and any pages tied to that section. Thanks!
well, here's the radio wiring diagram for all of you...
Radio Outputs:
12 Volt DC: -------- White
Switched Accessory: ------------ Red/ Yellow
Ground: ------------------- Black
Power Ant: -------------- Yellow/ Green
Remote turn on: ---------------- Red/ Yellow
Illumination: -------------- Red/ Black also red
Mute: ------------------ Yellow/ Green (for amp mute), Blue/Red (for hands free link mute)
Steering remote wire: ----------------- Green/ Red
Left Front ------------ Green+ / blue-
right Front -------------- Black+ / Grey-
Left Rear -------------- White+ / Yellow-
Right rear------------- Orange+ / Red-
Center CH------------- Brown+ / green/white-
Sub ---------------- Red/ Blue+ / White/Green-
Anyone know why my 2007 base pre-amp wires for my rear speakers are not white+, yellow- and orange+, Red-?
I can't find a diagram anywhere. Can I use the fader and balance to determine which wire is which or does someone know? My wires are all light colors with stripes.
I have a similar issue for 08 with navi. The posted diagram does not match the wiring for my black or grey wiring harness'. Gonna try to sort it out but any help would be great!
i bough a pdf version service manual on eBay. it lack of navigation part from body electric. any one can send me the whole section of body electric. xuxianruan@126.com
Installing viper 5904 this weekend and I have everything I need for that part but am also installing 530t for windows and 529t for sunroof and was wanting a diagram for window and sunroof wiring so I know where all the connections are.....
Need wiring diagram for 04 tl tach input for remote start
Hi can someone please help me locating the ta h wire for 04 TL. My remote start works fine in warm weather but in cold it keeps cranking thrn blows air without the car actually running. This drains the battery.
Any help would be appreciated thank you
Please pm.me wireing diagram if possible for 04 tl.
Looking for wiring diagram for 06 TL navi and non navi (screen and clock). Trying to do navi to non navi conversion. Hard drive is not working and don't use navi screen since its out dated.
