Wiring Diagram?
Old 03-28-2006, 04:48 PM
Maddizm's Avatar
Wiring Diagram?
Anyone got a wiring diagram for a 3rd Gen TL? 2006 to be specific. Me and buddy of mine want to install a Viper 791xv ourselves. I guess I can just figure it out, but if somebody's already got a wiring diagram for the parts I need to hook up it would be easier. Thanks
Old 03-28-2006, 07:13 PM
Sec's Expert
streese's Avatar
PM me your email addy and I will send it to you.
Steve
DL78 (08-20-2023)
Old 04-01-2006, 09:30 AM
Sec's Expert
streese's Avatar
How did your install go? Wiring diagram work out for you?
Steve
Old 04-02-2006, 04:37 AM
Maddizm's Avatar
Thanks for the diagram. Haven't started yet tho. haven't had time. But I'll let you know how it goes. Thanks agian.
Old 05-05-2006, 12:54 PM
06 TL Navi wiring
I would also like the wiring diagram for 2006 TL
Old 06-11-2006, 09:38 PM
dglsmason's Avatar
2006 TL wiring
I would also like the wiring diagram - to install power for my Escort radar detector. Thanks!
Old 06-11-2006, 10:14 PM
B A N N E D
lookinco's Avatar
I am going to install the exact same alarm. Could someone please e-mail me the diagram too! please please please lookinco@shaw.ca
Old 06-12-2006, 07:13 AM
How may I help you.....?
jmbnova's Avatar
YO.. I hate to jump on the bandwagon but I am doing a secret project and the diagram would help me out alot... if anyone has it please send it to jmbnova@aol.com
Old 02-17-2008, 10:19 PM
EVNS TL
evnash's Avatar
can someone send me the diagram for an 05 non nav? evnash@gmail.com
Old 02-18-2008, 12:33 AM
lowendz's Avatar
this is not a wiring diagram, but, the spec sheet for the alarm and starters
12volts white (50A) + ignition harness
Starter black/white + ignition harness
Second Starter N/A
Ignition black/yellow + ignition harness
Second Ignition N/A
Third Ignition N/A
Accessory black/red + ignition harness
Second Accessory white/red + ignition harness
Keysense red/white - ignition harness
Power Lock pink/black - green plug, left side of fuse box
Notes: These wires will meter when using the passenger door lock switch.
Power Unlock pink/blue - green plug, left side of fuse box
Lock Motor yellow/black 5wi green plug, front of fuse box
Unlock Motor yellow/green 5wi green plug, front of fuse box
Parking Lights+ red/black + large white plug, top of fuse box
Parking Lights- red/black - headlight switch in column cover
Hazards green/red + large white plug, top of fuse box
Turn Signal(L) red/blue + large white plug, top of fuse box
Turn Signal(R) white + large white plug, top of fuse box
Reverse Light green + driver kick, harness to rear
Door Trigger see notes - rear of fuse box
Notes: The LF door is green in a 16 pin plug, pin 15. The RF door is lt. green/red in a 14 pin plug, pin 12. The LR door is green/yellow in a 16 pin plug, pin 14. The RR door is green/white in a 14 pin plug, pin 13. Use all four wires and diode isolate each.
Dome Supervision green/red - green 5 pin plug, rear of fuse box
Trunk/Hatch Pin blue/yellow - green plug, left side of fuse box
Hood Pin yellow/red or green/black - hood pin switch in latch
Trunk/Hatch Release yellow/green or blue/black + driver kick, harness to rear
Power Sliding Door N/A
Factory Alarm Arm blue/white to white/red - driver door module in door
Factory Alarm Disarm black/red to white - driver door module in door
Disarm No Unlock see factory alarm disarm
Tachometer NOT yellow/black ac any fuel injector
Wait to start N/A
Brake Wire white/black + brake pedal switch
Parking Brake green/orange - large white plug, top of fuse box
Horn Trigger green/yellow - horn switch
Memory Seat 1 blue/yellow - driver door module in door
Memory Seat 2 red/yellow - driver door module in door
Memory Seat 3 N/A -
Old 02-18-2008, 09:12 AM
EVNS TL
evnash's Avatar
Second Starter N/A
Second Ignition N/A
Third Ignition N/A
Wait to start N/A
Memory Seat 3 N/A -
thx but do you know what wire goes to the factory double lock beep?
Old 02-18-2008, 11:10 PM
lowendz's Avatar
if your hooking up an after market alarm, i would just hook up a relay with your lock output to your horn. so everytime you lock it, it would honk. or... just hook up the horn output from the alarm.
another is to get one of these...
http://www.idatalink.com/product/res...006&carid=4391
it would be the multi series AL CA, it does everything including transponder bypass, factory alarm arm and disarm, locks, trunk, status for doors hood trunk and a tach output.
all in one little module.
ive got it in mine. and have not had any problems.
Old 02-22-2008, 05:49 PM
Maddizm's Avatar
Do you want the double beep just or the sake of double beeping? Or do you want to arm the factory alarm? If that the latter is the case... then I agree with the above, get the bypass kit, it'll make your life a helluva a lot easier. No wiring the alarm to all four doors anymore!
BTW lowendz you get the windows down working again?
Old 02-24-2008, 12:26 AM
lowendz's Avatar
yep, ive got the windows to roll down automatically after i disarm if i want, roll em all up upon arming as well as leaving them a crack open. ive also got the smart perimiter sensor, smart tilt sensor, glass breakage sensor, smart shock sensor, smart back up siren, remote starter (made for manual and auto's). All from clifford avantguard 5.1
i put all this in myself so if anyone has any questions just ask and ill try or provide an answer.
Old 02-27-2008, 07:22 PM
3rd Gear
Allocri's Avatar
Hy everybody, can anyone send me the wiring diagram for a 2006 TL navy ? allocri@hotmail.com
Old 02-27-2008, 10:18 PM
Administrator
Ron A's Avatar
Received 1,006 Likes on 575 Posts
I sent you an email.
Old 03-04-2008, 09:02 AM
Aghajan1's Avatar
is there a wiring diagram for a 2005 acura tl??
Old 03-04-2008, 12:32 PM
Fulani has a TL's Avatar
Hey lowendz where did you mount the brain?
Old 03-07-2008, 07:06 PM
lowendz's Avatar
few places where u can mount it. i've got mine mounted right behind the vsa switch. however, I have everything else mounted under the center console (under the deck). the perimiter sensor is under the headliner just behind the sunroof. i've got to take the dash apart again, maybe i'll take a few pics when I do. (after I get back from my hawaiian cruise)
Old 06-08-2008, 11:04 AM
619creepin's Avatar
can anybody pm me the radio wiring diagram for my 05 tl millanro@saic.com
Old 06-09-2008, 07:38 AM
RobxMcCarthy's Avatar
Hey guys, hate to be a bandwagoner, but I've been looking for the wiring diagrams for an 04TLAT for a while. If you could help out that'd be awesome.
RobxMcCarthy@gmail.com
Old 06-22-2008, 10:10 PM
haywire2u's Avatar
I wanna hardwire the power cord from my Garmin into my 05 6sp TL. Looking for the wiring diagram
haydenvf@yahoo.com
Old 07-04-2008, 05:04 PM
Trew's Avatar
Hi Guys,
if it's no trouble, please send me a radio wiring diagram for a 2005 TL.
Thanks,
sr_trew@yahoo.com
edit: it's an auto trans if it makes a difference.
Old 07-05-2008, 12:03 AM
lowendz's Avatar
well, here's the radio wiring diagram for all of you...
Radio Outputs:
12 Volt DC: -------- White
Switched Accessory: ------------ Red/ Yellow
Ground: ------------------- Black
Power Ant: -------------- Yellow/ Green
Remote turn on: ---------------- Red/ Yellow
Illumination: -------------- Red/ Black also red
Mute: ------------------ Yellow/ Green (for amp mute), Blue/Red (for hands free link mute)
Steering remote wire: ----------------- Green/ Red
Left Front ------------ Green+ / blue-
right Front -------------- Black+ / Grey-
Left Rear -------------- White+ / Yellow-
Right rear------------- Orange+ / Red-
Center CH------------- Brown+ / green/white-
Sub ---------------- Red/ Blue+ / White/Green-
AMP OUTPUTS:
12 Volt DC: ----------------- White
Remote Turn on(input) ---------------- Red/ Yellow
Left Front ---------- Lt. Green+ / Purple-
Right Front ------------ Blue+ / red-
Left Rear ------------- Brown/White+ / Red/Yellow-
Right Rear ------------- Red/Blue+ / Yellow-
Center ---------------- green/White+ / Blue/Yellow-
Subwoofer ------------- Yellow/Black+ / Lt. Green/Red-
@ Speaker:
Left Front Tweeter -------- Lt.Green+ / Purple-
Right Front Tweeter ----------- Blue+ / red-
Hope this helps all of you,
Lowendz
Old 07-05-2008, 12:10 AM
04DCTL's Avatar
where can i get a helms manual for our car
Old 07-05-2008, 10:30 AM
King of Pain's Avatar
Here's what I have. This is for an 05 TL.
Old 08-03-2008, 05:40 PM
Maddizm's Avatar
WHOA nice!!! hahaha... i posted this a long time ago... thanks though! that's awesome...
Old 10-27-2008, 09:46 AM
techguy's Avatar
Hey guys, need some assistance. Do you have any pics or details as how to access the dome supervision wire. How do you access this "5 pin green plug"? What do you have to remove to get to it. I tried to eyeball around the fuse housing, I did not see it. TIA.
Old 02-27-2009, 09:01 AM
Chad05TL's Avatar
those scans are like a teaser since you can barely read it.. THey shrunk it down too small haha
Old 02-27-2009, 07:25 PM
rockstar143's Avatar
Received 20,007 Likes on 14,511 Posts
I bought my service manual on ebay...it came in CD format for the computer and only cost 7 bucks shipped. Has come in HANDY!!!
Old 12-30-2009, 01:16 AM
taylowa's Avatar
2006 Acura TL
Can someone send me (taylowa@gmail.com) the wiring diagram for a 2006 Acura TL? I'm trying to hook up a remote starter to my car, and I know I can use the factory remote with the unit I bought if I know what wire changes from - to + when I click the lock button on the remote. This is the primary wire I'm looking for. Also, I need to know if there is a easier place to get the Black/Red (factory disarm) then going into the door itself. One last thing, where is the Accessory wire for the AC/Heater unit? This is the primary reason for hooking up this type system.
Old 12-30-2009, 02:29 AM
nfnsquared's Avatar
Received 1,794 Likes on 1,347 Posts
Click here for wiring info for remote start/alarm.
Click here for a good DIY on a Viper 5901 install
No, there is no other way to access those wires. It's a real PITA.
The good news is that a door lock interface unit will save you from having to do that. Or get a door lock interface/bypass como unit like I did: the canmax400dei.
Last, for $10 you can get a 3 day pass to all Acura service manual and wiring diagrams online at helminc.com.
Old 01-20-2010, 11:48 AM
HarlemzFinest135's Avatar
I'm no wiring diagram genius so bare with me. I'm confused about the factory amp wiring. Please correct me if I'm wrong. From what I can read the A1-A14 cavities belong to the input plug and the B1-B20 cavities pertain to the output plug. Now my question A11 says it's constant power I'm guessing it's an input, why didn't they make it in the input plug.
Old 01-20-2010, 12:22 PM
I never understood that either...for some reason the remote turn on, the power and the ground are all on the "out" grey plug on the amp. Strange.
Old 01-25-2010, 04:13 AM
GlockandRoll's Avatar
Great thread... thanks!
Old 04-05-2010, 05:01 AM
4th Gear
kaszub's Avatar
2005 wiring diagram
Hi,
can somene send me (kaszub66@yahoo.com) 2005 TL wiring diagram?
Thanks!
Old 04-05-2010, 10:28 PM
av6t's Avatar
Hi, Can some one please help me out, either by telling me how to find the diagram on helminc.com which i pay the $10 for three days when i login it takes me to https://techinfo.honda.com/rjanisis/logon.asp there i can't find the links the wiring diagram for my 2005 TL.
or
can someone sent me the wiring diagram for the 2005 non-navi radio and display and the 2005 navi radio and gps display and the GPS controller wiring diagram,
I am trying to do a non-navi to navi conversion.
TIA
Will
Old 07-27-2011, 07:51 AM
2005silverTL's Avatar
I need a wiring diagram for 05 Navi, specifically need the auto dim mirror and HFL pinout.
Thanks.
Old 10-27-2011, 11:31 AM
TrentH's Avatar
wiring diagram 2005 Acura TL side mirrors
Hello,
I need a wiring diagram for 2005 TL for side mirrors. I replaced actuors and side mirror switch assembley. Please help.
Old 01-09-2012, 01:01 PM
tpoony's Avatar
Hi RonA, I am getting ready to do a Timing belt change on my 2006 TL, planning to do the start bump method to remove the pulley, would greatly benefit from having a fuse diagram so i know how to pull the fuel injector fuse.
Can I please trouble you to send my the fuse panel wiring diagram to poony69@hotmail.com?
Thanks!
Quick Reply: Wiring Diagram?
