Wind tunnel
Old Jun 8, 2004 | 10:52 AM
dnice's Avatar
Wind tunnel
Has anyone said to you that you sound like your in a wind tunnel while using the HFL? I have a SE T-616 and while crusing at highway speeds people tell me this. At first I thought the sunroof was cracked open, but that wasn't the case. Just trying to see if anyone else experienced this.
Old Jun 8, 2004 | 10:13 PM
pedalermike's Avatar
Yep, I've had the same complaints - maybe its the noise suppression algorithms in the HFL causing a case of the warbles... I've also had other complaints like static and drop outs. I"m using a Motorola v600 which has generally been pretty reliable except for the TRANSFER problem.
Old Dec 24, 2004 | 08:54 AM
8-)'s Avatar
8-)
...just another stooge...
Ok, I know this is old. I found this with a search. YES, I have the same problem with my SE-T637. It's annoying. Did you find a fix?
Old Dec 24, 2004 | 11:42 AM
rets's Avatar
Moderator Alumnus
Did you guy try to delete your old paired profile and re-pair again?
le^2
Mar 17, 2026 05:06 AM
Dec 7, 2020 05:39 PM
xsilverhawkx
Oct 5, 2015 11:00 AM
Froid
Sep 27, 2015 06:16 PM
Sep 17, 2015 08:57 PM
