Why does the HFL not want to pick up calls?
Alright here's the thing. I can call just fine. However, when i get a call, the HFL saids you have an incoming call.... Great up to here, but after a few rings and i press the talk button, the HFL decides to return to a blank screen. I have to press the talk button again to go to the hand free screen and press the back button to converse with the caller. WTF? However, as soon as i get a call and I press talk, then it's fine. However, if i even wait 2 rings or something, the problem occurs. Is this somehting that the dealershipo would fix?
6th Gear
I have the same problem - Verizon Motorola V710 - works great making calls - but when I go to answer an incoming call It will seem to connect then dump me back to the stereo - If I hit off/hang up then back to answer it will sometimes connect - Verizon had no clue why - said it had to be the car.
2005 TL Navi SSM Auto
