Where is your iSimple unit?
Old Feb 10, 2011 | 11:06 AM
mook1524's Avatar
I need to update my isimple and i am trying to figure out where it may be so i dont have to tear apart everything! I bought the car with it installed already! I have a '05 tl with navi. Thanks in advance for your help!
--Jesse
Old Feb 10, 2011 | 11:28 AM
jptl04's Avatar
Bone stock tl-s
look in the trunk, behind the trunk linner in the dvd rom drive corner. it sould be connected to the XM antenna, its a square with connectors going to it. it's right above and to the left of the dvd unit. two bolts hold it on a metal frame support.
Old Feb 10, 2011 | 12:14 PM
rainmn's Avatar
Since the OP has a 2005, the iSimple isn't going to be in the trunk.
In the pre nav-traffic cars, the unit connects at the back of the stereo, not in the trunk.
Mine is right behind the stereo, and is accessible without taking anything apart. Next to your gas pedal, pull the carpet out a little from the console area and look in there with a light. Odds are good it will be in plain view.
Old Feb 10, 2011 | 01:57 PM
CarologistFB's Avatar
I second this ^^^^ my adapter is in or near this location as well
Old Feb 10, 2011 | 01:58 PM
jda123's Avatar
Dogmatic Dinosaur
It is likely behind the stereo. The unit plugs into the leftmost connector on the stereo. If you cannot find the unit easily, then take the panels off and follow the connector from there. I have seen some installs where people zip them behind the stereo and you have to disassemble to find it.
When you put it back in, there is enough cord/harness to keep the unit up under the dash where you can get to it by only removing the lower panel where your feet go.
Old Feb 10, 2011 | 02:23 PM
natedoggydog's Avatar
Mine is behind the panel next to my right leg on the side of the stereo when in the drivers seat.
Old Feb 10, 2011 | 02:31 PM
mook1524's Avatar
Wow thank you so much for all your help! Now hopefully I can get my stereo working correctly!
--Jesse
Old Jun 3, 2011 | 09:58 PM
av2600's Avatar
rather than create another thread.... i have an 08 type s, can i stash the isimple + ipod in the trunk near the xm unit? I dont need access to the ipod
Old Jun 9, 2011 | 04:04 PM
PaulM9999's Avatar
AV2600,
I don't think you can put it in the trunk- you'd need a real long head unit adapter to place it that far away. If you don't want the iPod cluttering your center console, you can probably find a way to tuck it into the back of the control panel along with the iSimple.
I have my iSimple against the plastic wall to the right of the gas pedal. My iPod is in the top of the center console, but it could really go anywhere, since the iSimple cable to the iPod is pretty long.
Good luck.
Old Jun 9, 2011 | 09:55 PM
kirill1221's Avatar
I recently installed the iSimple and mine is located right inside the panel directly under the steering wheel. Its necessary to take it off anyway to install so I just tucked it right in there. The way I see it is I only have to take off one panel to access it.
Also, if youre going to be doing the install yourself, you will notice next to your right knee is a small vent on that same panel. Im pretty sure that panel regulates the air inside in terms of whether in car circulation needs to be on or not. Its a small sensor that I would recommend cleaning out because dust does get in there.
Old Jun 9, 2011 | 10:04 PM
csmeance's Avatar
I put mine under the cupholders in the center console and ran the wire for the ipod through the two comparments.
To access it is pretty easy, remove the silver strips and 4 screws and I just have to slide the center console back to get to the unit for any reason.
Old Jun 15, 2011 | 05:35 PM
Mafyoso's Avatar
Balling in the...
I thought the iSimple in 07+ connects in the trunk.
Old Jun 15, 2011 | 05:53 PM
kirill1221's Avatar
On 07+ it is in the trunk but on 04-06 it connects in between the xm connector harness right behind the headunit. I can't tell what the op has because I'm on my phone but if it's 07+ lucky for him because that is much easier to get to than the previous years. Ask me how I know.... Hahaha
Old Jun 15, 2011 | 06:14 PM
Drewman752's Avatar
i have mine under the radio, basically were the right foot is. behind that panel to access behind the radio. held in there with velcro.
Old Jun 16, 2011 | 01:27 PM
av2600's Avatar
thanks man, on my 08 the connector should be in the trunk then too. Now to find a cheap isimple on ebay...
Old Jun 16, 2011 | 03:05 PM
kirill1221's Avatar
Anything in the 100 dollar range is going to be good. That's how much they wholesale for. Stay away from anything lower than that as it might be a knock off.
Old Jun 18, 2011 | 10:34 PM
tj2003_25's Avatar
I put my Isimple box right behind the rad with Velcro when i want to get to it i just have to remove the clock and ac vent and i can get to it easy
dirleton
Aug 6, 2024 08:19 PM
Jul 16, 2017 07:33 AM
brboy
Oct 5, 2015 11:34 AM
Eggs999bacon
Sep 24, 2015 10:08 AM
