Where to put the 3.SIXTY remote? Please help
Old Dec 22, 2006 | 06:19 PM
meyersnole's Avatar
Hello, I have read through a ton of systems (how I got started in the first place) and decided to tweak my setup just a bit with a 3.SIXTY.1. While I see many references to people having the 3.SIXTY installed now, I have only seen one picture of the remote location... and I am not interested in giving up my cup holder. Can people please tell me where they put theres and the pros/cons of that location?? Thanks a bunch! BTW, anyone else considering a 3.SIXTY, check out crutchfield. They have reconditioned ones for $199 shipped. Thanks in advance for your help.
Current setup:
NE-774V (4Channel LOC) ---| Replace with 3.SIXTY.1
NE-7V (2Channel LOC) ---|
Front channels JL 300/2
Rear channels to 2 channels (100x2) of a JL 500/5
Center channel input bridged 3rd&4th channel (25x2) of the JL 500/5
Sub to Sub channel (250x1) of 500/5
The JL 300/2 powers two 6.5 Focal components for front channels.
The JL 500/5 sends rear channel info to two Focal 6.5 coaxials.
The JL 500/5 sends center channel Focal 4" coaxial in dash.
The JL 500/5 powers a JL Audio 10W3v3 in the trunk.
Old Dec 22, 2006 | 09:08 PM
rodneyc77's Avatar
Retired!!! ON TOP!!!
check the location here... http://.com/phpBB/viewtopic.php?t=30
Old Dec 22, 2006 | 11:54 PM
meyersnole's Avatar
Thanks... how long have you had it there? Any downside to its location? If you did it again would you put it in the same place?
Thanks!
Old Dec 23, 2006 | 08:32 AM
zax123's Avatar
Team Anthracite Member
I have the 3sixty.1 too, and believe it or not, I didn't even hook up the remote. I have subwoofer control from the stock head unit on the navi screen so I didn't see the need for additional bass control... am I the only one?
Old Dec 23, 2006 | 08:52 PM
jptl04's Avatar
Bone stock tl-s
when i had mine i used it for the volume control, not bass control. although i still used my oem knob/ steering wheel for main volume control, i would play with 3sixty control to tweak the sound. so i'd put it in place were you could easy access to
Old Dec 26, 2006 | 12:29 PM
rodneyc77's Avatar
I've had it there for at least 4 months now... no downside... yes, I would put it in the same place because it's out of the way and it doesn't bother me one bit...
jptl04 & zax... you guys are both right... I barely tweak the system with the control... I usually do it with the factory HU, but barely... it's like an infomercial... "you set it and forget it"... lol
Old Dec 27, 2006 | 08:36 AM
zax123's Avatar
I wonder if I'd get even MORE thump if I hooked up the remote. hehehe. I'm actually very happy with what I have now. :P
Old Dec 27, 2006 | 11:39 AM
jptl04's Avatar
Bone stock tl-s
yes you will! like i posted before i used the 3sixty remote(knob) as the vol. not bass, cuz i already had a bass knob comming from my JL 500/1. i was always tweaking the sound using the 3sixty remote along with the oem vol. knob. the JL bass knob was the one that i rearly used. you will get higher highs and louder bass, the way i had it. thats why it was perfect where i had it. when get my 07 i will be installing it in the same spot.
Old Dec 27, 2006 | 11:27 PM
Knertified's Avatar
when I install, I will either take the remote apart and drill out one of the spacers in the dash if the knob can fit or just mount it inside the center console (might need to drill hole for wire)
rockyboy
Aug 4, 2024 10:35 AM
miner
3G RLX (2013+)
36
Jan 11, 2016 04:17 PM
GraveDigger
Sep 18, 2015 07:46 AM
GraveDigger
Sep 17, 2015 11:53 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
