Visualogic VMOD (Media On Demand)
#161
1st TL-S on air in
I have tried the laptop as dual and in the presentation mode where it's only showing video on the external monitor. What I am concerned with is that my laptop won't natively go less than 800 x 600 and met said he had his set to 640 x 480 and I can set a custom mode for the secondary display of 640 x 480 but I don't know if that's actually working as it should.
Yep I definitely checked continuity from the pins on the RGB cable to the wires and they match up.
I don't have the service manual with me but I think 12 is the sync if those other 3 are the RGB because I remember them being 1,2,11,12.
Yeah I have the supplied cable plugged into the VGA in and then the traditional 3 row 15 pin in plugged into the computer.
#162
Any idea what that app might be?
#166
Thanks for checking, I'll look at what my manual says when I get home. What pin are you showing is the sync pin on the 20A harness?
#168
#170
#172
Wow, I have just finished this whole thread, complete with the linked threads within it. You guys are doing a great job of figuring out these issues. Like a great thriller, I can't seem to put it down! lol
I too am in the initial planning stages of my CarPC. I also want to maintain the touchscreen control. My PC is actually a laptop and I will be using either Centrafuze or DigitalFX (RR Skin). I installed my NavTool 2 weeks ago with my backup camera and I have the Blitzsafe unit in the mail to me for sound integration. I also have a ScanDo 800 waiting to go. My main question is about power. How are you powering the PC and ScanDo? I saw the links to the actual units you were using, but my question refers to how the power is being controlled and conditioned (for lack of a better term). Do you have a delay setup so the unit does not start sending power until after the engine has cranked and is running? How are you handling shutdown controls? I'm thinking that I can sidestep some of these issues by using the laptop and setting the power control options within Windows to handle the shutdowns, which still leaves the power on questions. Don't really want to send surges to my equipment.
Again, thanks for working through all of this and sharing your experiences with the rest of us. I certainly appreciate your efforts and can't wait to see the final DIY come from all of it.
Dave
Dave
Last edited by dwb993; 05-05-2009 at 07:59 PM. Reason: BTW--subscribed to this thread.
#173
1st TL-S on air in
Dave
Dave
#174
Alright well first I'm a moron ... I had the closed and common wires going to the wrong connector, I switched those wires and re-tested and after a bit of playing around I now have video on my nav screen!!!
But there is an extremely noticeable flicker and I'm not sure what's causing that. I have uploaded a video at the following URL ... maybe you have some thoughts on it?
http://www.hawksquawk.net/dolfan23/m...cker%20Vid.avi
Oh and thanks dwb933, wrxyboy has been a HUGE help as you can see throughout this process and while it's been extremely frustrating the majority of the problems for me can be chalked up to being a newbie at this stuff but even with that I'm getting close. As for powering the scan converter I am using a device that I bought which was recommended on mp3car.com as something better to use than the PCs built in power supply. Whether that's true or not I don't know but it works beautifully for me. Here is the link to it: http://jopeldesigns.com/acppsv1.html
#175
#177
I still can't believe I had the common and closed wires backwards, I guess I wasn't thinking too clearly about which of the plugs goes to where. I'm just happy to know that the scan converter works and that I'm close to getting this to work. Talk about exciting
#179
I was able to get the video working in my car today at lunch, I just tried an older laptop with XP on it instead of Vista and it worked fine without changing anything. I did install PowerStrip on it because I couldn't get the laptop any smaller than 800 x 600 and that caused the display area to be larger than the navi so it scrolled left, right, up, and down. I didn't have time to really mess with PowerStrip to see where I can force a display size but it did report that the navi was capable of displaying 640 x 480 but only at 16 bit color. That should still be good enough though to run RoadRunner on it.
#180
1st TL-S on air in
Yeah if you can get that stuff to work that you were wanting that would be really cool!
#181
Well how about this, PowerStrip to the rescue! I found the setting where you can force the output resolution and I set it to 640 x 480 and 16bit color and I was pleasantly surprised at the results! Here is a quick video that I took with my Blackberry and although it looks pretty good it's much better on the screen.
http://www.hawksquawk.net/dolfan23/misc/Acura_X-Men.avi
#183
Yep there should be lots of info in this thread for anyone else wanting to try it based on all of my screw ups LOL. Now I just need to get a little money together to buy an actual carPC and then I'll be set. Once again I sincerely appreciate all of your help!!
#184
Very cool, Jay. Glad to hear its working for ya. ![Thumbs Up](https://acurazine.com/forums/images/smilies/thumbsup.gif)
I'm not quite ready to begin working on this full time---still collecting parts and right now I'm having issues with the headrest monitors I want to use. Once I get ready, I'm sure I will be hitting you guys up for guidance.
#185
#186
I bought a set off Ebay and they need some re-soldering. I have never soldered before. Luckily, my roommate is mil-spec certified in it. I just have to get his ass to do it. He doesn't realize it yet, but he may be doing my touchscreen controller, too!
#187
1st TL-S on air in
I did the easy escape on the touch screen controller and bought 1/8" female connectors from ebay and crimped them on. So all i had to do was plug and unplug to make changes on the relay very easy, the only soldering i had to do was the fcc connectors from the touch screen and fcc connectors from relay to circuit board. I would recommend buying heat shrink wraps so after you are done you just heat shrink them and you are good to go they are very cheap less than $2 at home depot. Also make sure you buy really good rca connectors as they will make a big difference in screen quality as compared to the generic brands.
#188
Hey guys... First I'd like to say great work on figuring this out! I stumbled upon this since I purchased a 07 TSX and was looking to use the factory touchscreen for my carpc. I have a few questions that maybe you guys could answer for me.
1) Why use a bulky relay when you could just extend and run the flat flex wires directly to a toggle switch which would switch between the factory unit and usb controller?
2) For the video, I read on a separate forum that you could hack into the backup camera input and supply the screen with a RCA video input which you could easily supply from a laptop or such. I wasn't sure of the method you supplied the factory display with video. A link would be appreciated.
Thanks.
Thanks.
#189
1st TL-S on air in
Thanks.
Thanks.
1. Because there are 4 wires from the touch screen, 4 wires from the usb controller and you need take all the info from either of those 4 wires back to the factory circuit board. So there are a total of 12 wires and a relay makes it possible to only control one item at a time either the carpc or factory navi system. I think you would need to do a minimum of 8 toggle switches to work the carpc or factory navi.
2. Main reason being that video quality on a RCA video input is very poor as compared to the native signal of using the Scan Do 800. There are two units that you can use to get the signal to the navi screen, doms unit and navtool both of which comes with a plug and play harness. Here is the users manual on the scan do 800 http://www.blackbox.co.uk/technical/...A%20Manual.pdf Hope that helped clear up some of your questions.
#190
So this is the list of items that you will need.
- Carpc this is the obvious one of course.
- Touchscreen usb controller (http://shop-on-line.tvielectronics.c...ch-controllers)
- Scan do. This may be the hardest item to find but you have to search hard for it.
- Items need for the relay between the touchscreen usb controller and video feed from the navi unit/ car pc. All can be found at www.digikey.com
1. FFC, FPC (Flat Flex) - Connectors - Board Mount QTY (2)
http://search.digikey.com/scripts/Dk...me=609-1814-ND
2. FFC, FPC (Flat Flex) - Connectors - Board Mount QTY (2) These are different from the ones above.
http://search.digikey.com/scripts/Dk...me=609-1928-ND
3. FFC, FPC (Flat Flex), Ribbon - Jumpers QTY (1)
http://search.digikey.com/scripts/Dk...ame=WM10013-ND
4. RELAY PWR 3A 4PDT 12VDC QTY (2)
http://search.digikey.com/scripts/Dk...l&name=Z186-ND
5. RELAY SOCKET 4PDT EYELET QTY (2)
http://search.digikey.com/scripts/Dk...l&name=Z812-ND
- Toggle switch
- The following items are all optional parts but i purchased them anyways in case i wanted to do upgrades.
For audio you could use the aux in the middle console, but i went ahead and bought the pie x3
http://www.logjamelectronics.com/piex3auxconv.html
If you want to use the gps features of the front end program than you will need a gps usb receiver.
I bought a amp kit to run the power wire from the front to the rear and i also bought a 2 farad capacitor to prevent any drainage to the battery and a distributor block, but this is also good in case i want to put in a nice sound system everything is ready to go.
And dont forget all the necessary pc cables to extend things from front to back.
- Toggle switch
Here is where I am currently:
Dell XPS Gen2 or Latitude D820 laptop base PC (D820 has a dockstation I can use, too)
Lind Auto power adapter for Dell PCs (on order)
CarNetix P2140 185 watt power supply (for ScanDo 800 and any other equipment needing clean 12v power)
NavTool video and BlitzSafe audio (already installed)
I have been able to hookup the PC to the ScanDo to the Navtool and control it with a BT mouse---all using external power. It works nicely but merely points out how close I am to actually achieving what I want (touch screen control).
Also, have either of you looked into mapping some of the other radio buttons to control the PC---I have seen threads from others where they have been able to make this work, too.
If csmeance happens to be viewing this thread (or if either of you have communicated with him) has he been able to make the PnP touch screen controller I have seen mentioned in threads? (I guess I will PM him directly).
Finally, have you had any reliability issues or any other commentary on the general experience? Can I count on you guys if I run into serious trouble?
Thanks a lot!
Dave
#191
1st TL-S on air in
Hey guys! Been a while, I know. I am finally getting to turn my attention to this project and I needed to check on the parts list for the relay and touchscreen taps. Is this parts list still valid? Are there any additions/deletions I can make based on your experiences?
Thanks a lot!
Dave
Thanks a lot!
Dave
I thought about looking into mapping other keys but have been busy with other projects on the car so once all that slows down than i can read into mapping other keys.
So far the system has been working great and i would love to incorporate a nice sound system but one thing at a time. I am usually always online during work hours so if you have any problems i should be able to help you with it. Let me know if there are any thing else i can do for you.
#194
ACURA TL
I have been working on my carputer for about 6 months now and I am very close to being done. Im using mac mini with Extron 109XI converter ... how do connect the BNC wires get connected to the relay? when cutting the BNC wire to expose the internals... there are two wires in each cable.. is on of these a negative? if so where does to connect to.. terminal 13 ground in the car harness?? i tried connecting the grounds to the chassis but it fried my mac mini as a result... any ideas?
calrow
05-03-2017 10:21 PM
InFaMouSLink
11-11-2015 12:19 PM
SinCityTLX
55
10-11-2015 01:20 AM
