Vibration when sound is high
Old 04-03-2016 | 10:22 AM
Enrick Gatien's Avatar
Bigboy6029
Hey guys, when the volume is high in my Acura Tl (05 base AT) it looks like the subwoofer is causing a shaking. Problem comes from the platform under the rear window, actually where the sub is. it is really annoying and i wonder if it's just a plastic adjustment or something like that.. thanks for the help !
Old 04-03-2016 | 11:32 AM
princelybug's Avatar
LIST/RAMEN/WING MAHSTA 짱
It's a known issue with all 3G TL's. Click below link, and pay attention to post #32:
https://acurazine.com/forums/audio-b...le-fix-713239/
Old 04-03-2016 | 11:43 AM
Bigboy6029
You are the man haha thanks !
Old 04-03-2016 | 04:44 PM
mazen222's Avatar
quick fix i did was the fold a few small pieces of cardboard and slip them between the top platform and the glass. Make sure they're nice and tight.
only downside is that u can see them in the rear view mirror if they're not black
Old 04-05-2016 | 07:06 PM
MarcoNorthPolo's Avatar
KCCO
As mazen said, you can put things on the back deck to stop the vibration. I suggest taking the carpet away from the top of the trunk, that way you can get at the BOTTOM of the rear deck. There are only a couple of plastic clips holding it on. I put in some cloth and foam in order to push the deck against the glass and also to form a cushion. It stopped the vibration completely. Then put the carpeted part back on. This way you don't see anything from inside the cabin.
TSX69
3G RLX Audio, Bluetooth, Electronics & Navigation
94
09-17-2018 08:45 PM
bscc0808
05-03-2016 08:57 PM
OculiAquilae
03-05-2016 01:29 PM
ericcdong
02-12-2016 12:10 AM
TheChamp531
01-05-2016 03:18 PM
Quick Reply: Vibration when sound is high
