Using Moto Razor V3 with HFL
Old Apr 20, 2005 | 08:10 PM
gainful's Avatar
I have paired the my Moto V3 with the TL HFL. But every time getting into the car I have to turn the bluetooth power of Razor on so that the HFL can find it.
Once I switch the ignition off, the connection is lost, and the bluetooth power of Razor is turned off automatically. I have to go through the menu to turn it back on again.
is there a way to keep the bluetooth power always on?
Old Apr 20, 2005 | 10:18 PM
dkrift's Avatar
I don't have that problem.
Old Apr 20, 2005 | 10:45 PM
socalshyguy's Avatar
There are 2 ways to turn on Bluetooth on the V3. The first is temporary: the menu options are Connection / Bluetooth Link / Handsfree. When using this menu option, you'll note the prompt "Temporarily Power On". The second is Connection / Bluetooth Link / Setup / Power / Change (to turn it on). My experience is that the second option stays until you turn it off, but the battery consumption increases dramatically when Bluetooth is on all the time.
If you were already aware of the 2 options, my apologies. It wasn't my intent to be insulting, and I'd rather error to the side of being helpful if you weren't aware.
When I use the temporary option, Bluetooth isn't dropped immediately upon turning the car off - it takes a while, though I haven't timed it. I have noticed on a short stop in this scenario, Bluetooth is still on and pared when I return to my car.
Old Apr 20, 2005 | 11:06 PM
gainful's Avatar
Thank you socalshyguy. I wasn't aware there are two options. I agree the bluetooth antenna will remain on for a while after offing the car.
Old Apr 21, 2005 | 08:03 AM
GregC1968's Avatar
Socal hit it on the head. My razr works well with my HFL.
On another note, I turned on my razr this morning, and the screen was white. Then the oto skin that came with the phone wouldn't stay fixed, but rather would move from left to right? It finally corrected to the normal screen when I hit the red end call button. When I picked up the phone later , it was doing the same thing.
Anyone have this happen to them? Suggestions?
I have Cingular with flex version GSMV3xxCIN01Na04E.
Thanks in advance.
Old May 14, 2005 | 02:22 PM
Msnowdon's Avatar
Does anyone get the Battery Indicator on with HFL?
Old May 14, 2005 | 02:36 PM
DEG's Avatar
DEG
Nope. Signal strength only.
mada51589
Jan 9, 2025 04:40 PM
phillyguerrilla
Sep 26, 2015 11:27 AM
rmittal
1/2G MDX (2001-2013)
Sep 19, 2015 08:41 PM
cali boy 91
Sep 19, 2015 01:57 PM
Markbby06
Sep 17, 2015 02:30 PM
