Turning off the navi
Old Mar 1, 2005 | 07:34 PM
NiceRide's Avatar
I like the way the Navi screen stays black if you don't ack the legalese.
Question: is there any way to recreate this, or turn off the navi, once you have started to use it?
Sometimes its nice to have the darkness.
Old Mar 1, 2005 | 08:34 PM
big_kid_buck's Avatar
The love is for the car
Yes just go under setup and hit display, and screen off will do the trick
Old Mar 1, 2005 | 08:41 PM
NiceRide's Avatar
excellent, thanks for the tip
Old Mar 2, 2005 | 10:13 AM
Pankul's Avatar
Computer Techie Geek
or just use the voice command "diplay off"
Old Mar 2, 2005 | 02:59 PM
acuraTL44's Avatar
Is there a voice command to turn the screen on? and a way to turn it on if you did not press "OK" at start-up? using buttons?
Old Mar 2, 2005 | 03:10 PM
1995hoo's Avatar
Keep Right Except to Pass
There is no way to bypass pressing "OK," including voice commands. If you don't press "OK," NO voice commands will work.
If you voice-command the display off, maybe saying "Display on" or "Display map" might work. "Display map" works from other screens.
Old Mar 3, 2005 | 08:33 AM
SilverQuartzTL's Avatar
"Display off" is not a recognized command
If the display turns off because you didn't accept the nag screen, just push any button and the nag screen will be right there waiting for you to press OK.
Old Mar 3, 2005 | 10:16 AM
Pankul's Avatar
what are you talking about ??? I use it everyday ... and just in case you misunderstood me. IT TURNS OF DISPLAY, it has nothing to do with the NAG screen. there is no way around other than pressing OK.
Old Mar 3, 2005 | 11:24 AM
1995hoo's Avatar
"Display on" works. I tried it last night. You have to be past the nag screen first, of course.
Old Mar 3, 2005 | 12:03 PM
We must be running different versions. "Display Off" no worky with my 05 TL. What version are you running?
Old Mar 3, 2005 | 12:23 PM
93SHOcar's Avatar
I thought it was a two step process to get the voice commands for this: "Set up" (gets you to 1st set up screen), then "Display Off" causes the screen to go blank. This is on a 04.
Old Mar 3, 2005 | 12:42 PM
Woops! Just to add to the above. If you say "display off" from the Map/Guide Screen, it is interpreted as "display hotel or motel"
HOWEVER, if you you say "display off" from setup screen 1. Buh-bye goes the display.
Saying "Map/Guide" or display on, or pressing just about any button will turn the display back on.
This is actually pretty cool, but honestly, I haven't found a case where I really want the screen off
Old Mar 3, 2005 | 02:43 PM
Pankul's Avatar
I have an 05 TL as well. will verify again tonight, cos I almost swear I use it without going to set up first.
handsom-hustla
Nov 13, 2015 05:04 PM
MoAbbas
Oct 3, 2015 07:44 AM
Vejey Gandier
Sep 12, 2015 08:59 PM
lovic87
Sep 9, 2015 10:18 AM
Gianni Formica
Sep 7, 2015 08:28 PM
