Turn of TL Nav when driving?
Old Sep 12, 2008 | 07:06 AM
mswol's Avatar
Is there any way to turn the screen off once driving?
Old Sep 12, 2008 | 07:11 AM
LoveMyTL-S's Avatar
I know if you don't touch the "OK" button when it first boots up it will go black after a minute or two. Not sure if you can turn it off after that.
Old Sep 12, 2008 | 08:28 AM
TeknoKing's Avatar
Of course you can, hit setup, you will see Turn LCD OFF button. To turn it back on press any button.
Old Sep 12, 2008 | 08:47 AM
1995hoo's Avatar
Keep Right Except to Pass
This is what I do when I drive in areas with no Navi coverage. You have to hit "OK" if you want to be able to use voice control for the radio and climate control, so I'll hit "OK," then "Setup," then "Display Off" (I generally use the voice command for this rather than fiddling with the buttons).
Note that if you're in an area with no Navi coverage and you display the "Audio" screen, that screen will remain frozen when you turn off the radio and you'll have to repeat the process noted above to clear the screen.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
Rocktman1
Sep 19, 2015 05:58 PM
PortlandRL
Sep 14, 2015 12:01 PM
andysinnh
Sep 5, 2015 11:38 PM
