Trouble with International Calls on HFL
I have tried using handsfree link to dial international numbers, example 0113027522599 and get a an operator message that the "call cannot be made as dialed , check the number and call again". Obviously, the number I am dialing is a correct number and even picks up the correct name on the cell phone display.
I suspect that the Link is inserting a "1" or some other number that is causing the international call to fail as a bad number.
Has anyone else encountered this issue?
it's me, Alan Rickman.
ehhh
011 + Country Code + Area Code + Phone-Number right?
Do you have international access on your cell? If you turn off bluetooth and make the call directly from the cell does it work?
HFL doesn't know what kind of call it's making; it just knows what numbers to send..
It is possible that you need to add pauses between dials. There are a few threads on calling international numbers. Search and/or check out the FAQ and see if anything in there helps.
Originally Posted by Timmahh
ehhh
I will search the threads some more ......
phillyguerrilla
09-26-2015 11:27 AM
