Tmobile branded V600
Old 07-29-2004 | 03:16 PM
HuKaShI's Avatar
T-mobile has just released their V600!
Has anyone tried it yet? Any problems right out of the box with it for our TLs?
I'm thinking of picking it up if it doesn't have problems with the bluetooth connection in our cars.
Thanks in advance!
Old 07-29-2004 | 03:28 PM
cullal's Avatar
Depends on the software version on the phone. I flashed to 45R and the V600 now works flawlessly with the HFL.
Old 07-29-2004 | 03:34 PM
HuKaShI's Avatar
Ok, so my next question would be;
Does anyone know what software version comes with the T-mobile branded V600?
Old 07-29-2004 | 03:43 PM
cullal's Avatar
On the phone dial *#9999# and the software version will display.
I am very interested as well. I need to make a decision on rather going with Verizon or T-mobile.
HELP PLEASE!!!
Old 07-29-2004 | 04:13 PM
HuKaShI's Avatar
Since I don't have the phone yet, can someone who does let us know what version it is?
Old 07-29-2004 | 05:08 PM
HuKaShI's Avatar
OK, I did a little hunting over at HowardForums.com and came up with the following information for the software.
S/W Version TRIPLETS_G_0B.09.3AR_A
DSP S/W Version 62D5C500
Does this mean anything to anyone?
Is this software version give a green light for TL and V600 mating?
Old 07-29-2004 | 06:37 PM
captain's Avatar
The T-Mobile V600 is tri-band. The ATT and Cingular V600s are quad-band. If you get the T-Mobile version and try to use it on the future ATT/Cingular network, you won't have a great experience as it will only have one of the US bands, the other two are the Euro bands.
Old 07-29-2004 | 07:42 PM
cullal's Avatar
You will have actually test the V600 with that version of the software with the TL to see if it works fine. I got my V600 from AT&T and it had software version TRIPLETS_G_0B.09.2DR and this version was not forwarding incoming calls to the HFL. I upgraded (flashed) my phone to TRIPLETS_G_0B.09.45R and it works just fine now. No issues...
Old 07-30-2004 | 09:58 AM
JetJock's Avatar
I have a V600 from ATT, and when I "dial *#9999#, nothing happens. What am I doing wrong. I'd like to check the version on the phone.
Old 07-30-2004 | 10:22 AM
firmie's Avatar
How do you flash the phones? I have the V600 from Cingular and it works with thte HFL, do I need to get it flashed at Cingular or AT&T?
Firmie
Old 08-01-2004 | 10:50 PM
stocks2k's Avatar
I have the V600 from T-Mobile, and have not had one problem with the HFL and the phone connecting, transferring or anything else. Perfect so far.
Old 08-02-2004 | 01:33 AM
Mtalio's Avatar
7th Gear
What does V600 show on MID?
Given that the V600 is working so well for you, what info shows on the MID? I'm considering switching my T-Mobile V300 to either V600 or SE T610 or Verizon V710. It seems that the Sony Ericsson phones consistently are showing the most info on the MID.
Mtalio
Old 08-02-2004 | 11:06 AM
stocks2k's Avatar
Mine is showing signal streangth, but no battery info. I am not really concerned about battery life while in the car, so not a big deal really.
Old 08-02-2004 | 01:40 PM
HuKaShI's Avatar
So you have full capabilites with this phone? You can answer calls with the clamshell closed?
Also a question on the phone itself. How is the service with the V600? Do you get good RF signals?
Old 08-03-2004 | 10:01 AM
stocks2k's Avatar
I just leave it in my pocket closed and have had no problems at all. I am getting significantly better signal streangth and fewer dropped calls than my V70 the V600 replaced.
Old 08-03-2004 | 08:58 PM
fendogz's Avatar
The V600 so far is working good. Get droped calls on the bronx river pkw, but thats the service. I'v always gotten droped calls on the pkway.
So far so good
Old 08-03-2004 | 10:12 PM
captain's Avatar
Just thought this was relevant to the last post...
Old 08-04-2004 | 09:44 AM
HuKaShI's Avatar
Will any of you guys try to upgrade the firmware to get the battery life to show in the MID?
Old 08-04-2004 | 11:13 AM
cullal's Avatar
JetJock, the software version is also on a label behind the battery.
Old 08-04-2004 | 11:15 AM
cullal's Avatar
HuKaShI, I upgraded (flashed) to version 45R and the battery life still does not show on the MID.
Old 08-04-2004 | 11:30 AM
HuKaShI's Avatar
Thanks for the info.
I was hoping the flash would have the battery life showing on th MID but I guess I can live without it. As long as all the other stuff works. Like being able to use it without the clam shell open.
Let us know of any other problems if you come across any!
Old 08-06-2004 | 12:22 AM
gche37's Avatar
Flashing the V600
Is flashing the phone something that the Cingular/T-Mobile/AT&T store has to do? Or, can you flash it in other ways?
Greg
Old 08-06-2004 | 03:40 AM
mobilezen's Avatar
Greg
Flashing is something that Motorola or a service center should do. Any other kind of flashing would risk voiding your warranty as Motorola frowns upon it.
I'm thinking about picking up a V600 tomorrow from T-Mobile and flashing it to see if I can enable 850...I think the software is different while the v600 internals are the same. hmm...
Old 08-06-2004 | 04:31 AM
JetJock's Avatar
Thanks for the info. So far my V-600 is awesome. I had a SE 616 for 2 months, and although it displayed the battery strength, everything else about the phone sucked. At my mothers house, the SE phone would barely hold a call inside the house, and in the basement I had no signal. With the V-600 the reception is fine inside the house...and to my utter amazment it even works in the basement. Great phone!!!!!
Old 08-07-2004 | 02:25 AM
HuKaShI's Avatar
I just got a T-mobile V600 phone to try out on my TL. I have successfully paired the phone to the car but it does not transfer calls to the HFL when the clamshell is closed. Are any of you with this phone having this same problem right out of the box?
I was hoping I wouldn't have to flash the phone.
Old 08-07-2004 | 11:29 AM
Vffr1's Avatar
Team Anthracite President
I just orderd my T-mobile V600, but I don't get the phone for a week (via snail mail). Keep me posted and I'll keep you posted.
Thanks,
Mike Smeezy
Old 08-07-2004 | 12:08 PM
HuKaShI's Avatar
Does anyone know if there is a setting that I have to change in order to make this work properly?
Old 08-09-2004 | 08:37 AM
fendogz's Avatar
I have 2 T-Mobile phones paired to the car and they both work just fine with the clamshell closed. I'v Checked and didnt find that I changed anything in paticular to make it work that way. I just followed the instructions on how to pair it from the acura website and both phones work just fine.
Triplets_G_0B.09.3AR_A
Old 08-09-2004 | 09:43 AM
HuKaShI's Avatar
It started working on its own for some reason. I guess I wasn't pressing the HFL button at the right time when a call came in. It works pretty much flawlessly now. Weird.
Old 08-09-2004 | 02:40 PM
Vffr1's Avatar
Are you all happy with T-Mobile service and coverage?
Thanks,
Mike Smeezy
Old 08-09-2004 | 02:55 PM
HuKaShI's Avatar
I wasn't all too satisfied with T-mobile when I was using the Samsung e715. But now with the V600, I get very good signal strength from the spots that were previously bad.
HuKaShI's Avatar
Another quick question about the V600. So, last night, I forgot to hook up the charger to the phone before I went to bed. Last I remember the battery was full. I look at the phone this morning and its down to one bar. I come into the office and the battery dies.
So now I have it hooked up to the charger and its doing its thing. I had it hooked up since 10:30 this morning. I just looked at it and it just shows two bars blinking. It is now 2:10 pm.
1. How long does it take to fully charge this battery from when its dead?
2. Another question is, does having the bluetooth on standby during driving have a significantly larger drain on the battery?
Old 08-09-2004 | 04:05 PM
fendogz's Avatar
I dont realy know how long it takes to charge, but My wife has been using the car since we've gotten our V600's and she has to charge the phone almost every day.
I havent charged mine in 3 days and the battery still has 2 bars.
I think the bluetooth does drain the battery alot faster.
Luckly they gave me a car charger!
08KBP_VA
10-22-2019 02:55 PM
mitchigan
05-29-2019 07:53 AM
Jboat
09-30-2015 11:58 AM
RSpyder
09-30-2015 01:46 AM
Quick Reply: Tmobile branded V600
