Time for a Remote Starter
Old Dec 10, 2006 | 09:42 PM
lyk3n0other8's Avatar
EBAYGEEK
Thumbs up Time for a Remote Starter
It's getting cold in Brooklyn
Its time for a remote starter.
What are the good ones?
What do you use ?
I need one with range, I live in a 4 story Condo.
Old Dec 10, 2006 | 11:39 PM
Buda's Avatar
Starcraft II addict
I have a compustar remote start w/alarm (2W900FM-AS). The one I have is 1/2 mile range (line of site) and does well when I'm inside a building. This one is the next to top of the line for Compustar. The top end one has a new FM transmitter on it that cycles through frequencies to find the one with the best ception. This can be flakky but if you need range (1 mile line of site) or to really get a single through a couple buildings than thats the one. I am quite happy with mine.
Price I got: Remote start 525 installed (with alarm add 200).
Compustar has a pro series as well. If you go with compustar, call them and ask for a list of authorized dealers in you area. I did this to ensure a solid warranty on the install.
Old Dec 11, 2006 | 03:46 PM
Juiced_Acura_Kidd's Avatar
Need 4 Speed...
If you want alarm + remote start, then the Viper 5900 is good too. It has the new SST Technology with a 1 mile range. Works great.
Old Dec 11, 2006 | 06:47 PM
skyy406's Avatar
Resident auto maniac
Can i get a remote start for my 6mt? probably not...
Old Dec 11, 2006 | 06:58 PM
Buda's Avatar
Starcraft II addict
^-- You can get a remote start for a MT. You just have to make sure to put on the e-brake and leave it out of gear. It usually is a little more expensive of an install on the MTs.
Old Dec 11, 2006 | 07:02 PM
ChicoOG's Avatar
I have the Viper 791...it's real nice to get into a warm/defrosted car in the morning
Old Dec 11, 2006 | 09:24 PM
revo's Avatar
Back in the saddle..again
I suugest compustar or viper. For MT cars compustar makes a model. You will need a bypass for the immobolizer i suggest the Honda-SL3 for the bypass you don't loose a key and it is simple. If you are doing it yourself get the CAN-SL2 also. More info at www.ifar.ca
Do not install an automatic starter in a manual. Get one that is made for manual that has a parking and door input.
Old Dec 11, 2006 | 10:42 PM
6MTUA5's Avatar
No He Can't
I was told by an installer that when they have to bypass the computer because of that chip you have in your key, it will void your warranty and not be covered if your car gets stolen. Don't know how true this is, but it was what I was told.
Old Dec 11, 2006 | 10:53 PM
ChicoOG's Avatar
If my car gets stolen, my insurance will cover it and they are more than happy I have additional security. As far as warranty, not sure what part of the warranty it might void. I'm sure the dealer would find something
Old Dec 11, 2006 | 11:09 PM
Buda's Avatar
Starcraft II addict
You do have to be careful what remote start system you get in the car. The TLs do have the immobolizer system and the remote start does have to bypass it. However there are big differences in how some remote start systems get around it.
All remote start systems have to bypass the immobolizer chip by making it think that there is a key in the ignition. There are two main ways that I'm aware of this being done.
1. You have to give the installer a physical key to install into the immobolizer. Keep in mind that you will not get this key back for this option. They will typically break off the key into the immobolizer bypass module. This allows the remote start to bypass the immobolizer, but the problem is there is still a physical key present in your car.
2. This option is similar to #1 however with a better result. You still have to give the installer a key, however you get the key back unharmed. What they do is to electronically program the bypass with the "fingerprint" of the key you provided. This is then used to trick the immobolizer into thinking that a key is present when the remote start system is activated allowing the car to be start. However in this case there is no physical key in the system. This is how the Compustar remote start system works.
In either case, when a person steps on the brake, the remote start system is deactivated and the immobolizer is reactivated. At this point if you don't have a proper key in the ignition in the on position, then the car shuts off. The immobolizer chip still works. I like the compustar solution (also on other brands) as there is no physical key used to bypass the immobolizer chip. Since no physical key is present no chance to take the car.
I got my remote start with an alarm system as well. Does this mean my car will never get stolen or broken into, NO. What it does mean is that such a person will see that bright a$$ alarm LED and go to the car 2 spaces down with no system and break into that one to avoid the hassle of attracking unwanted attention.
Does this in some aspect "void" the warranty for part of the car. Yes, but it's more toward the anti-theft aspect of it. As far as functionality goes or if the immobolizer stops working, the dealership has to prove that the remote start system caused the problem otherwise the defective part is still under warranty.
Hope that helps. These are the same types of questions I had when I looked into mine. Luckily I had a helpful dealership and a very reputable installer.
Old Dec 11, 2006 | 11:20 PM
ubnpast's Avatar
What do you use ?
You can get an "add on" remote start for around $50, but for an extra $100 you can get a full alarm with 1 mile radius, all the goodies, just use new key fobs... In fact the range is so good, that when I was in school it would actually page me in class when it was going off, I had to keep it on vibrate so it wouldnt attract everyones attention.
This is the newer version of what I had, you can find them on ebay for around $150: http://www.ultrastarters.com/4265.html
Also here: http://www.ultrastarters.com/Featur...ature_Sheet.pdf
Viper IMO sucks, my sister has the 5000, almost no range, 300' and you loose range
Yes, they make specifically manual transmission remote starts, some (like the one I had), you stopped the car, pulled up the e-brake and 1). tapped the brake pedal twice, the car stayed running and you got out and shut the door, when the door shuts, your car shut off or option #2). stopped, pulled up ebrake, pressed a button on the remote, got out, shut the door, car will use the turbo timer for 4 minutes or press the button on the remote to shut it off. It is fail-safe.
Some places may be, but not all of them, the only difference for a mt is that the clutch switch must be bypassed (cut the 2 wires), and a wire must be tapped into the e-brake ground.
Old Dec 11, 2006 | 11:58 PM
Buda's Avatar
Starcraft II addict
Beware of some of the cheaper remote starts. One option I'd recommend on the remote start item you chose is that it doesn't allow the starter to be cranked when the system is started via the remote start and is still running (i.e. you didn't press the brake to deactivate the remote start system). It's so easy to forget that you don't need to crank the key all the way as it is habit. Cheaper remote start system may not protect the starter.
Old Dec 12, 2006 | 02:42 PM
ubnpast's Avatar
^Anti-grind
Old Dec 13, 2006 | 12:41 PM
ITL's Avatar
ITL
I do my own work.
so if I were looking for a kit to install myself on my 6MT, what would you guys recommend?
I put one on my old Accord and it was a piece of cake. I would love to have the ability of leaving the car running while I took the key and got out for a few minutes (run into store) while leaving the car protected. This would allow my carpc to stay on as well as disable the car if someone tried to steal it.
I wouldn't want to cheap out, but I don't need the most expensive either.
Old Dec 13, 2006 | 03:01 PM
ubnpast's Avatar
I would suggest you get these 2 things, PM me for a wiring diagram, tells you where and what color the wires are.
ALARM, click here
And also a transponder bypass module, DEI makes a good one, just look for one where you dont have to leave a key in it. I dont see any of the alarms on ebay right now, but there should be some listed soon (I hope).
Feb 25, 2020 09:57 AM
Powder Monkey
2G CL Problems & Fixes
Sep 9, 2018 12:55 AM
forrie
Sep 15, 2015 09:57 AM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
dlknight
Sep 3, 2015 07:54 PM
