switchback bulbs
switchback bulbs
I have finally decided to do the switchback lights for my front and side markers. Which lights did you use for each. I have been looking at AutoLumination.com for bulbs. Did you use a 20 30 48? And is there a DIY for doing the side makers?
^ I have the same ones. You don't NEED the resistors but I would suggest them. If you do not put them in your blinkers will blink super fast and it is annoying...I still need to install mine, it's been too cold out!
this thread should help you.
https://acurazine.com/forums/showthr...switchback+led
I got mine switchbacks and resistors from v-led's, this is what I got
http://www.v-leds.com/Shop/Control/C...pid_15680342=1
you can also do a search for switchback led's and you will find TONS of threads with useful info here
good luck
^ sorry forgot to tell you if you are ordering form v-led's try these 2 codes
CLUBLEXUS
ACURAZINE
i don't know if these still work but give it a shot, they should be for 15% off if they work.
CLUBLEXUS
ACURAZINE
ripit
09-26-2015 06:19 PM
