Suggested AV Switch Audio Relay Method
Old Oct 4, 2004 | 05:59 PM
hondasaurus's Avatar
I'm not sure how much different this would work in comparison to using the AV input/output method.
http://share.shutterfly.com/osi.jsp?i=EehNWbZi1buHg
Check out the schematic drawing. You'll need to pull the audio wires from the XM Harness and replace new lines from harnass to the relay. Both old and new audio wires connect to the non switch ends of the relay. 2nd new audio wires from AV connects to the switched end of the relay. The relay is switched on from the DVD remote power.
Any other inputs would be great.
Old Oct 4, 2004 | 07:53 PM
chusteveb's Avatar
hey cool diagrams, let me see if i can't share with you what i have
http://im1.shutterfly.com/procserv/4...63f60000004613
It's showing the same thing as yours in a different way.
Old Oct 4, 2004 | 08:00 PM
chusteveb's Avatar
Old Oct 5, 2004 | 11:47 AM
http://share.shutterfly.com/action/s...&x=1&sm=1&sl=1
Another method by cutting the audio lines and putting the 4pole relay in between the harnass and the radio.
I'll post more info once I get the relay installed and tested.
Old Oct 6, 2004 | 11:39 AM
chusteveb's Avatar
Yes please do. I'm really not liking how it cuts the audio in half on the XM and movies. I'll be starting to work on that myself here shortly.
mada51589
Jan 9, 2025 04:40 PM
Feb 25, 2020 09:57 AM
tallyrlx
3G RLX Audio, Bluetooth, Electronics & Navigation
Feb 26, 2016 03:44 PM
01CLOwner
Oct 9, 2015 01:07 PM
siularbar
1/2G MDX (2001-2013)
Sep 11, 2015 10:40 AM
