subwoofers
12" Alpine Type-R 4-ohm
Rockford Fosgate 500.2
Rockford Fosgate 4 Gauge Wiring Kit
Uncald4 Fiberglass Box
Here is the original miracle box
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/system-works-686412/
Here is a mini version.
https://acurazine.com/forums/3g-tl-audio-bluetooth-electronics-navigation-94/mini-dreambox-build-%3D-decisions-decisions-2ohm-4ohm-dual-single-coil-763323/
AZ O.G NoOldManVetteOwner
^Uh this is in the 3G TL section I hope you know.
LIST/RAMEN/WING MAHSTA 짱
Actually, I spoke with Travis directly over the phone and he recommended the exact sub that I have, for the box that he was fabricating for me. He knows his stuff, so I went with his exact recommendations.
Even a 6" sub potentially wouldn't be fully utilized in that box. Maybe he'll chime in for his .
My goal was functionality and performance, with an emphasis on functionality. Hence why I went with this specific enclosure.
I've got 2 12W6s in a bandpass ported into the cabin, no bass in the trunk. This is truly the only way to play it at high volumes without worrying about rattles.... and it's so much more efficient. This is the best sounding system I've ever owned and it goes louder than anything I've ever owned. Too bad CSWBiggs is not on here to post pictures of the original. I'll take some pictures this afternoon. I went to get the camera to take pictures and found that the GF had it with her at work so it will have to wait.
Here is the original CSW build which is what I copied. Mine looks much more ghetto as it was my first attempt at building a box.
I agree the box is likely too small (hard to tell by looking at it) but it does look to be ported on either side.
New York state of mind
all the hate on my bass
haha but do you think its really too small?? i had it done at a shop here in south florida and the guy def knew alot and we decided what would be best for what i wanted...but i dont know shit about installed boxes and what not so do you guys think he fucked it up?
i spent a bit of change on this so id like it right >
apparently, he didn't know shit.
those subs need MASSIVE sized boxes to perform properly.
Honestly, even with 2 12's ported, u wouldn't be able to fit the proper enclosure in that trunk.
If u want to do it right, ditch them for better spl subs.
If u like it, keep it the way it is.
But do know that they can sound way better and get alot louder in a better box
It really pisses me off when shops take advantage of folks who don't know much about audio.
it sounds pretty fucking loud and clear as is, way better than my ported kicker box in my honda
the sound from the box is BIG and clear/smooth so he cant have messed it up to bad
my only qualm is the lack some high bass in the old school jungle tunes i play often, was thinking of getting another smaller sub
thoughts?
higher notes? screams lack of midbass.
How's your front stage looking?
1 may be able to fit.
the 15 calls for a minimum of 3 and a maximum of 6 cubic feet for each.
You should aim for around 4 cubes after port and sub displacement.
This is an old pic, since then i put in a 2400 watt orion amp on the floor behind the subs and tinted the tail lights darker.
3 - 12" pioneer premier subs
2400 watt orion competition amp
Spinnin them beats
Uploaded with ImageShack.us
:shurg: Simple, works. But i REALLY want a smaller box. Cant get my spare tire and its simply too much space. Its a 12w6v1... think i can get unclad's box?
Here is my last set-up but I changed some things around since then.
TC Sounds TC-1000 in a small sealed box with an Alpine PDX.1-600 for power. Nothing flashy just clean sound
