Subwoofer Help
Old Jan 7, 2005 | 02:36 PM
shalinz's Avatar
Subwoofer Help
I had 2 10's go out on me a while back. I just got the replacements in and put them into my box. I hooked everything back up the way it was before, but I am not getting any bass out of them. I do get a poer light on the amp so I know that there is not a fuse blown anywhere.
I even replaced my lineout converter thinking that was the problem but that did not help. I tried plugging into the amp through the high level inputs and the RCA's but nothing seems to help. I can plug the wires back into the stock sub and that works so I don't think it is the witing to the lneout converter.
Anyone have any suggestions?
Thanks for any help.
Old Jan 7, 2005 | 02:40 PM
bluenoise's Avatar
2004 SSM/EB/5AT/Navi/RSB
This may be too obvious, so no insult intended...
Is the subwoofer slider turned on in the Audio settings at the front end?
Old Jan 7, 2005 | 02:43 PM
shalinz's Avatar
Yep sure is, that was one of the first things that I checked. Not offended here, of courseI would be pissed at myself if it is something very simple.
I also made sure that the gains on the amp were up, which they are. I tried 2 amps, and I know both work, cause I just had them tested not too long ago. Both subs were sent to me brand new. The ones I had before are no longer made, so they sent me 2 new ones of a different model.
Old Jan 12, 2005 | 02:42 PM
shalinz's Avatar
ok got it figured out. It was my stupid ground cable for the AMP. the shop that did my wiring put the ground wire a little over the insulation in the spare tire well and that was causing the problem. I reloted the wire and now everything works perfectly fine.
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
