Subwoofer box + trunk tray?
Old Aug 13, 2007 | 08:45 PM
saiwahhh's Avatar
getting a 12" sub into my TL in a few days, and i have the trunk tray (the all season thing, dont know how else to describe it?) anyway, what were you guys able to do when this situation came about? put the sub box into the tray, and drill ll brackets into the tray as well? remove the tray? no brackets?
just wanted to see what others have done. thanks
Old Aug 14, 2007 | 03:20 PM
markgrise's Avatar
7th Gear
I assume you're talking about the spare tire well. I wouldn't use it, what if you need the spare? Build a box and sacrifice the space, provided you don't use your trunk all the time. You can always build a box that can you move around your trunk if you need more space. I built a down-firing box with a 10" Boston G2, and it sounds great. If I need space, I slide the box over. Not competition, but it's practical. With it being down-firing, the woofer is not exposed to being damaged when items are placed in the trunk. Just a thought.
Old Aug 14, 2007 | 06:33 PM
AngeloUCF's Avatar
'05 6MT w/Nav A-Spec
I wouldn't assume that at all. Seems like he was just wondering what people do with the trunk try when they get a box. I plan on just drilling into the tray.
Old Aug 15, 2007 | 01:25 AM
saiwahhh's Avatar
angelo is correct. drilling eh? what if leakage occurs?
Old Aug 15, 2007 | 01:00 PM
lembowski's Avatar
Trucki!!
I guess if your worried about leakage put a water tight sealant around the screw holes. Use clear.
I don't worry about leakage, since I really don't have anything wet I put in my trunk......just sandy.
Old Aug 15, 2007 | 01:22 PM
stillhere153's Avatar
94 DC4 RS LSV/Turbo
sell me your trunk tray... problem solved
on another note if you are worried about leackage, then why wuld you put the sup there... put the sub where the stock on is, 10"
Old Aug 15, 2007 | 09:06 PM
saiwahhh's Avatar
because i already have a 12" in a box from another car, and i like it and its cheaper than buying a whole new setup.
Old Aug 16, 2007 | 11:04 AM
RJANACONDA's Avatar
Registered TL Lover
if your going to drill put plywood under the carpet to drill into that.
mlody
Dec 4, 2019 02:11 PM
Jul 16, 2017 07:33 AM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
