subwoofer
Old Dec 23, 2006 | 04:06 AM
sontipheap's Avatar
subwoofer
Has anyone replaced the factory subwoofer to an aftermarket subwoofer. Please let me know how and what size subwoofer it could fit in the rear deck?
Old Dec 27, 2006 | 03:30 PM
mblanton66's Avatar
It has never been done.
Old Dec 27, 2006 | 04:02 PM
Converted's Avatar
THE PLANE TAKES OFF!!!!!
NO... no... and no!
The factory sub is small, and limited.
You can not put most modern aftermarket subs in it's place because they require a SEALED box, or a properly designed ported box...
Using a powerfull sub in the open air just doesn't work well, and will sound like garbage. That, and there's not much room to begin with.
Old Dec 27, 2006 | 04:43 PM
Adobeman's Avatar
The DVD-A Script Guy
Agree
Unless you are planning to add an amp there will be little to gain by just upgrading the driver in the OEM hole. Even with an amp it might not be that great either. There are subs that are designed to work with an infinite baffle (like the OE driver) but your choices will be limited.
Old Dec 27, 2006 | 04:51 PM
Kennedy's Avatar
OMGWTF4THGENTL
There are numerous folks who have replaced the stock sub with a JL Audio 8" w3v2...
As stated above, though, to get solid bass, you have to seal it up. I'm gonna try and run it Infinate Baffle with an e1200 amp. It may not be optimal, but it has to be better than stock.
AndrewS
19
Mar 14, 2024 06:59 PM
BoricuaTL
Apr 8, 2016 01:08 PM
kb1rl
Sep 30, 2015 10:17 AM
jmaxima03
Sep 27, 2015 10:22 AM
3GTLOwns
Sep 9, 2015 09:51 PM
