Which Subs?
Old Apr 19, 2006 | 06:41 PM
akunc88's Avatar
4th Gear
Which Subs?
I have a 2005 Acura TL does anyone reccomend a good subwoofer system, I want 2 12"s or a 15" but I want it to sound good for the small space??
Old Apr 19, 2006 | 07:00 PM
OoBALLERoO's Avatar
i myself have 2 12" sony xplods in my trunk that are 1300 watts each and i believe 250 watts rms.. let me tell you..these subs hit hard. i set off car alarms everywhere i go..the only problem is that the trunk area rattles like crazyyyyy do u definitely need to invest in some dynamaat
Old Apr 20, 2006 | 04:27 AM
Nurse's Avatar
i have 2 10in kicker solo baric L7's 1200 watts MAX/600 RMS in a bandpass box ported through the rear seat armrest. 0% vibration and no need for dynomat. i still have plenty of trunk space too.
Old Apr 20, 2006 | 04:39 AM
Nurse's Avatar
i meant 0% trunk rattle
Old Apr 20, 2006 | 08:28 AM
sirbentley's Avatar
I SAID GOOD DAY!!
What kind of music do you listen to? If you go with Alpine, Kicker or Kenwood you really can't go worng. Go to a shop and listen for your self. If you're from chicago go to ABT in Glenview. Good Luck and Bump Loud
Old Apr 20, 2006 | 12:02 PM
akunc88's Avatar
4th Gear
do you have any picture of how you have it ported through the rear seat
Old Apr 25, 2006 | 08:29 PM
HowQuaint's Avatar
Yes, I too would love to see some pictures of this....
Old Apr 26, 2006 | 01:40 AM
Nurse's Avatar
here are the pics. i haveent finished the cosmetic portion of the port. i will put a mesh on the port to conceal the inside. it will have to do for the mean time. What do you think?
l
Old Apr 26, 2006 | 01:57 AM
JOES05tl's Avatar
Can't see the pic.
Old Apr 26, 2006 | 02:01 AM
Nurse's Avatar
[QUOTE=Nurse]here are the pics. i haveent finished the cosmetic portion of the port. i will put a mesh on the port to conceal the inside. it will have to do for the mean time. What do you think?
sorry. lets try this again[IMG][/IMG] [IMG][/IMG] 7/caxgadh79uj.jpg[/IMG][/IMG] [IMG][/IMG] [IMG][/IMG]
Old Apr 26, 2006 | 02:05 AM
Nurse's Avatar
here is two more[IMG][/IMG] [IMG][/IMG]
Old Apr 26, 2006 | 08:10 AM
Black_05_TL_6SP's Avatar
Ryan Christopher
The question of "which subs" is a very subjective question. What once person may find appealing in a sub may not appeal to another. Case in point, the L7's in a ported box, I personally don't like the sound the produce. It is a loud setup, but not the type of bass I listen to. I like tight, low bass. Ported boxes produce the frequency at which the box is tuned to. This is usually around 55hz. That means the subs will be super loud at that frequency, but will not produce the low 30hz sounds that well. Think of a bell curve, with the center of the bell curve being the frequency the box is tuned to. As it slopes off on both sides, this is what happens to you bass response. A sealed box is going to give you a smother curve. It will be able to start at a lower frequency and carry up and then start to cut off around 100hz-110hz. If you really want to see what I am talking about visit some of the Sub manufactures websites and look at the graphs. Here is one to give an idea Polk Audio This is not just my opinion on this, I have been installer for 8 years and have built alot of boxes and designed alot of systems. So the more appropriate question is, "which subs should I go with if I want loud bass?" or "what should I get to have clean accurate bass?".
Old Apr 26, 2006 | 11:33 AM
AcuraVic's Avatar
Ak Ting Up
So, give some suggestions for a direct sub replacement for the OEM that will provide crisper bass (clean accurate bass). While your at it, recommend some speakers for the rest of the car that will provide crisper highs (clean accurate sound).
Old Apr 26, 2006 | 11:58 AM
MisterLinus's Avatar
I have Lucy tied up in
Agreed ABT is the greatest electronic store ever.
For my personal opinion JL Audio make unreal subs, if you want something cleaner sounding, the Eclipse Aluminum sub is unreal, but both subs require some serious power.
Old Apr 26, 2006 | 02:19 PM
aznbo187's Avatar
I would go with a single elemental 16.o.v2, in a sealed box. I think it would compliment the TL sound system very well, without overdoing it.
Old Apr 26, 2006 | 05:04 PM
Nurse's Avatar
You are absolutely right about the base response being different from a sealed box. I went with a sealed box until the ported box was made. I can tell the difference but not that much to change my mind. It was a choice between “tighter” sounding base or trunk rattle. Yes I can go with dynomat to help with rattling but with the amount of watts I’m pushing it wouldn’t get rid of it all. I can’t stand hearing that awful sound of trunk rattle in such a beautiful car like the TL. It’s all about personal preference. To balance off the base, I changed the interior speakers as well. Boston Acoustics SL 60 components in the front and SL65’s in the rear. As the above picture shows, I have one Punch T4004 bridged going to the subs and the other for the interior speakers. I left the center channel alone. I used the LC6 Audio Control for the pre-amp signal.
Old Apr 26, 2006 | 07:38 PM
rajtl's Avatar
a very good cheap sub that dont need much air space are the new jl audio 12w1v2's you can get them for around 115 to 130 and they sound very good they hit very hard
Old Apr 26, 2006 | 08:55 PM
Ryan Christopher
To be honest, I wouldn't worry about putting one into the factory location. First, if you are planning on using the factory amp, not enough power. Second, it is a freeair style mount, not going to be accurate bass, as there is no real air resistance behind the sub. Third, if you are going to install a amp, you should do a sub box. Wheter you choose to do a custom fiberglass box. As I have done here.
Or a traditional box of some sort (ported, sealed, bandpass).
Personally I like the Polk Audio equipment. The new SR series speakers are great. They are offered in componets and subs. As for the rear speakers, that would be whatever you wanted to use. I have a set of 6 3/4" Polk MOMO mid bass drivers.
For the most part, choosing your speakers should be done with what you plan on doing to it. If you are not going to use a aftermarket amp in a car, you won't want to use some of the higher end speakers, as they require more power and really wont hold up well on either a factory radio or even an aftermarket radio.
I have a Audiobahn 5.1 amp mounted in the tire well. That way it is hidden and it runs all the speakers in the car.
The best thing to do is to go and listen to the speakers on a demo board at your local car stereo shop. If you are in the Huntsville, AL area come see me at Circuit City, and I can let you hear what some of the Subs would sound like in your car.
Jason
Old Apr 29, 2006 | 03:13 PM
AcuraVic's Avatar
Ak Ting Up
Thanks for the info, Jason. I may roll up to huntsville just to listen to your system someday. The 'in store' speaker setup never sound the same to me once I get them in the car. I think your setup is great, but not for me ( 10 years ago, definetly!!). I like the car to 'look stock' but perform like aftermarket.
Old May 1, 2006 | 09:38 AM
rickneuropa's Avatar
Subs are ver sujective, but I will put my vote in for eD-Elemental Designs subs, as they are designed for smaller enclosures, but go very deep, and very loud. They are SQ subs, that can really pound with less power than many other big manufactures, and can easily outperform those big names. Check them out, the prices are very good, and the support is outstanding. You won't be dissapointed.
http://www.edesignaudio.com/us.php?cur=USD
Jul 16, 2017 07:33 AM
InFaMouSLink
Oct 30, 2015 09:43 AM
kb1rl
Sep 30, 2015 10:17 AM
Birdflunuggetz
ILX
Sep 28, 2015 01:14 PM
