Which sub will provide the most bump (spl) sealed enclosure
Bella Nova
Okay guys I'm not an audiophile but do appreciate good solid bass, not the kind that makes your ears ring for half the day. With that, any constructive opinions would be definitely appreciated. Currently I have 3 subs that I have acquired over the past couple years and I need to get the best bang out of one of them. They are the Kicker S8L7, Alpine SWR-1042D, and the Rockford Fosgate 10" P3. And yes I know these are the mainstreaming product but all of these were purchased prior to me knowing anything about the real deal stuff like Sundown, DD, etc. So I won't be throwing out any mo hard earned cash anytime soon. I have a Kenwood KAC-8105D rated @ 500 rms x 1. I NEED my trunk space so that kind of eliminates a ported setup, so which sub would suit me best in a fiberglassed enclosure in the trunk corner. Yes, this will be a sealed set up but which sub can I squeeze the most bump out of?
thanks a lot fellow TL'ers.
Coolest A-zine Member
SPL and sealed usually don't go together. Especially when your only using 1 woofer at 10" or smaller and 500 watts haha. Also, if you've already got a fiberglass enclosure then how do you plan on fitting a square sub like the 8L7 in it? It's square and 8". Is yours a 10" box?
Conclusions: If you want SPL, true SPL, then sell all 3 and pick up a better woofer.
Bella Nova
Bella Nova
nice, I just tried it quick w/ some junk boxes & the L7 is a performer. Hard to tell which was louder but I'm sure your right on. Too bad the bolt line up doesn't match between the p3 & type are. I will have to try later. Why does the L7 do so well with slightly less cone area & power rating?
I know you said you didn't want to do this but if I were you I would seriously consider selling all 3", you don't even have to make a huge profit or sell them for a bunch...just enough to get the SA-8 from Sundown. That little fugger is a beast! Will sound MUCH better than anything you have there and get louder. It's pretty cheap at like $150 I believe so you should be able to pick one up very easily after selling all 3 of those subs. Don't settle just because ya don't feel like working at selling them...you'll want more shortly after you put it in I bet.
The L7 is built to handle/perform more for SPL oriented setups rather than the older Type-R and the P3. The P3 might get slightly louder and sound better but I've always hated Rockford subs and especially their new stuff. I'd have to look over the specs for those subs to say exactly which would be the loudest. As far as cone area, comparing the square 8" to a 10" round, the total area is less than half what it would be when comparing a 10" round to a 12" round.
Bella Nova
so true TL noob, that SA-8 looks awesome. I wish I found out bout those brands early on. I've seen some clips from the ssa web & they look fierce. Has anybody tried porting a fiberglass enclosure? It seems that never happens?
Bella Nova
Bella Nova
I dunno but just based off the more stoic look & a lil higher power rating it seems the type-r is the bigger player. Just my 2 cents. Hey Noob, is that also your 2 cents or is it based on actual listening experience?
No I've heard all of them but noone can make conclusions unless you hear all the setups of the same amp being used in the car. The l7 will get loud but sound like shit doing it. With those setups your not going to get any crazy SPL levels so my thought would be to get one that sounds the best and still gets loud. I've never liked the new rockfords as they're unreliable but the type r has always been a decent budget sub..and it's gotten better through the years.
Bella Nova
I loaded this enclosure with the P3 & I must say it hits pretty good! I now notice new rattles I've never heard before. Funny how things never seem to be just right in the audio spectrum, I was wondering if my old JL 8w3v2 would bump harder in that same enclosure. Of course I would have to modify it & add a port. What do you guys think?
I have to agree the Phoenix Gold sub would by far be the best. Has better frequency range and efficiency(also my fave brand period).
Still the I go with an earlier post with Type r, L7, P3. Truth is the P2 is considered a superior sub to the P3(in the real world price vs performance).
Dude really you don't need to even consider a 8inch if you trying to go for a Loud system. Typically the 8inch won't have the freq range and excursion you need to really get that ummph. There are some that can, but decent spl is usually left to the 12 and up crowd(even 10"). Shoot if you put the cash out and research into it you can find more than a few 10/12/15" subs that can go loud and clean.
Bella Nova
My box is not pre-fab, I fiberglassed it into the trunk corner with a flat mdf baffle. I have some bracing in there and its pretty stout. The P3 is not really that bad, but of course I have little to compare since this is really my only 2nd glass project. My previous setup was the 8" L7 sealed in the trunk corner and it performed decent. I've did the L7 in ported configuration and it pounded! but the box was so intrusive into critical trunk space. I also have the JL 8w3v2 and it too gets pretty low for an 8, I made a ported box a while ago to JL specs. However like the L7 the w3's ported arrangement is rather bulky. I've talked with JL tech and they gave me some figures where I can port my trunk corner fiberglassed box, which is perfect since the box wouldn't be residing right in the middle of the trunk.
Bella Nova
Here's a shot of my most current sub set-up. Mind you it's not complete, just gotta carpet it and its good to go.
Another shot of my previous set-up opposite side of trunk with my Kicker S8L7.
Bella Nova
Lol....tell that 8" can't get loud to Digital Designs. 1 8" will blow the doors off 90% of the mainstream systems out there. Obviously though, more cone area = more spl. The question was spl in sealed...with choices given. The rsd is FAR from a good buy but might be okay for an average listener. OP..if you ask me, I think you'd be much happier going towards the sq end than the spl end. Loud is just....loud. Doesn't really mean much if it sounds like crap.
Dogmatic Dinosaur
Why is it always one or the other? You can find several SQ subs that will get loud enough for permanent hearing loss. Do you really need it louder than that unless you are competing?
Bella Nova
yes sire, I'm trying to squeeze out the best from what limited product I have. I'm not going to buy any more new audio equip. Apparently I've accumulated a few mainstream products that can't match the lesser-known but more superior brands. Only if I knew about those non-mainstream items I would've bought the SA-8 sundown or the DD-1508 and been sitting on cloud nine with hearing loss. Unfortunately I didn't JDA123 so that is why I'm asking for constructive opinions. I do have materials around the house that I can use for multiple projects so I'm not really dumping in more money into my system just good old elbow grease with what I already have.
hmmm interesting thread..
my friend is debating on weather to get a 10" Type R, old school JL or that PG that you guys are talking about. I told him to get SSA but he said he doesnt want to pay that much. He works @ BB so he gets a discount on the main stream stuff.
WE listen to the same kind of music, but I'll show him this thread and see if he feels differnt about it now
Bella Nova
You need to ditch the sealed and go 4th order
You're using an 8 with a little amount of power so you don't have cone area or power at your advantage..might as well go with the most efficient box design.
You can have low end extension, high efficiency, or small enclosure size. Pick two.
If he's dead set on BB products...the type-r is easily the best they carry. I wouldn't say no to an extremely cheap Type-R...obviously there are better but they aren't terrible (they've actually gotten quite a bit better of the years). His box type is going to be more of a factor than the sub though....screw BB for that
