Stupid ? - How do you set the clock?
The clock in my car is still behind by an hour since the time change on Sunday. I went through the setup menu in the nav for the clock setting and it is correct in there. It's set on auto for both daylight savings and time zone. So what's the deal? Why is it correct in the setup menu but not on the display? More importantly, how do I change? Please save RTFM replies. Thanks!
Weird, the Navi should have adjusted the time automatically. I would change the setting on daylight savings, then change it back, the navi should kick in at that point.
Don't you mean it is still "ahead" an hour? It would appear to be behind an hour if you were looking at a watch that you hadn't adjusted yet.
You'll have to let us know what the problem was.
Originally Posted by xristos
In case you haven't driven the car. What about driving the vehicle 4 a couple of minutes, since the clock relies on the GPS satellites.
I think it may be because I'm running the Honda Navi OS instead of the Acura OS. I will put the Acura back on tonite and see if that was what's causing the problem. I just can't believe I'm the only one with this problem.
Did you ever figure this one out? I just got my car a couple of days ago and I have a navi, but the digital clock is about four hours off! My navi boots up with a Honda symbol instead of Acura. I've also had the navi freeze on me, and neither the touchscreen nor the buttons under it would respond. The crazy thing is that it would still repond to voice commands.
Appreciate any help!
Dealer replacing nav unit
Well, I brought the car in and the dealer couldn't figure it out, after ripping out the dash and testing all the leads. They're ordering a new NAVI unit for me and I have to bring the car back. What's annoying is that now I have rattles and the panels aren't fit together perfectly anymore. I'll wait until they finish putting the new unit in and see how the fit is once it's all back together...maybe they rushed it cuz they knew they'd have to take it apart again. If they do a crap job again, it's staying there until they do it right. This WAS a brand new car. I shoulda made them fix it before I took delivery...
