Stock subs
Old Dec 23, 2006 | 12:55 AM
sontipheap's Avatar
Stock subs
I have read thru a previous thread. Is it correct that you can't replace the stock sub with an aftermarket sub because of space issues in the rear deck? In terms of the aftermarket sub, the JL 8W3v2 is the only one that can fit? I was looking into the JL 10W3v3 so I guess it can't fit because the thermal power handling is 300W instead the 8" would be only 125W. Am I correct with that assumption?
I was thinking putting a box w/ 2 10" JL but I wanted it to be simple, clean and save space thats why I am looking into replacing the old stock sub.
Old Dec 23, 2006 | 12:02 PM
csmeance's Avatar
the 10 can't fit because there is not enough room in the shelf for it, it would require alot of cutting and reinforicing.
Old Dec 23, 2006 | 12:12 PM
sontipheap's Avatar
stock subwoofer
I guess my only option is to buy 2 10" subwoofer. I looking in purchasing 1 10" jl speaker the enclosed box. Do you know any website which sells JL audio speaker cheap?
Old Dec 27, 2006 | 07:19 AM
Converted's Avatar
THE PLANE TAKES OFF!!!!!
More importantly than room... you NEED proper airspace for most subs, ESPECIALLY a brand like JL, which is designed to run mostly in sealed enclosures.
It will not work properly, or sound good, in the open air.
hashbrown
Feb 18, 2022 11:20 AM
Jul 16, 2017 07:33 AM
vpasla1
Sep 17, 2016 07:24 PM
kb1rl
Sep 30, 2015 10:17 AM
