Stock Look w/ Louder Speakers...
Hey Guys
I have an 05 TL and I like the sound quality that I get out of my speakers, but I wanted something a little louder and clear...
Any of you guys have suggestions on how I can get a little louder deeper and clearer sound without putting custom boxes (and bunch of other stuff)? I really like the stock look and was thinking why not just replace the speakers and put a better amp than the stock...would that work?
Originally Posted by SILKO
Hey Guys
It's nice to see someone with the same issue as me. I love the way it looks, I just want a little more juice as well. Is it pointless to swap out the speakers without upgrading the amp, will it even make much of a difference?
I think theres a thread on this of some guy on here is doing something similar to it.
https://acurazine.com/forums/showthread.php?t=170169
I'm not sure what the power rating of the stock amp is, but given that the speakers are rated @ approximately 85 decibels (which is yucky), you would have a much louder system if you replaced them with 90+ decibel drivers. What it boils down is how many decibels can the speaker put out @ 1 watt @ 1 meter. The higher the sensitivity rating, the more sound you'll get.
http://www.crutchfield.com/App/Produ...107DB501&tp=98
Although they are rated @ 4 ohms, their sensitivity of 93 decibels is awesome. If you can find the same 90+ speaker @ 2 ohms, you'll be set. The higher the ohm load, the lower the power. If you wire an amp to play speakers at 4 ohms, the speakers will recieve less power than if they were being played by the same amp at 2 ohms. The bottom line is that you really SHOULD match the impedance of the amp to the speakers.
I'd replace mine, if my TL wasn't a lease.
Jul 16, 2017 07:33 AM
DerrickW
Nov 15, 2015 05:52 PM
