Static on radio after amp installed?
Old 05-18-2013 | 01:21 AM
simran4h's Avatar
hey, i just had my amp installed and because of this my radio has a lott of static when turned on but it is all ok when playing music through cd and aux....i had removed the green wire for the rear mic from the rear lights....any ideas y?thanks
Old 05-18-2013 | 09:07 AM
ELDeFontes's Avatar
I have this too. Even when my headunit is off. Silly.
Old 05-18-2013 | 10:35 AM
I hate cars's Avatar
Are you running a JL HD or any other class D amp with it mounted near the antenna?
Old 05-18-2013 | 10:51 AM
simran4h's Avatar
Yea I have a rockford fosgate t10001 bd amp mounted right on the side of my sub...could tht be the problem?
Old 05-18-2013 | 11:22 AM
Pull the fuse from your amp and see if there's still static. The class D amps can leak RF and interfere with radio reception if too close to an antenna. It's not common but it has happened.
simran4h (05-19-2013)
Old 05-18-2013 | 04:21 PM
ELDeFontes's Avatar
If that doesn't work. What's the fix? My fuses have been replaced on my Nakamichi amp and it's still continues.
Old 05-18-2013 | 05:38 PM
Is this meant for this thread.
Old 05-19-2013 | 02:03 PM
simran4h's Avatar
oh ok so i take the fuse from the amp out and then turn it on without the fuse being in there right?will cause any problems using it without a fuse and also do i have to replace it with a new fuse?thanks
Old 05-19-2013 | 03:17 PM
All you're doing is isolating the amp as the source of the problem. The goal is to kill power to the amp. You can do it however you want but I figured pulling the fuse would isolate just the amp itself.
Old 05-20-2013 | 07:40 PM
ELDeFontes's Avatar
Yes it was for this thread. I have static in my speakers as well, even with the headunit off.
You referred to taking the fuses out, not sure why'd I'd do that, it's there to protect the amp. I figured you were referring to changing the fuses out, a process I've already done.
Old 05-20-2013 | 11:46 PM
This thread is for a different problem. He does not have static all the time, only when its on the radio which is probably RF from a class D interfering with reception. Here, were talking about a sub amp causing noise over all speakers. I think you took your signal post stock amp which would be your noise problem.
You can pull the fuse, cut the turn on wire, disconnect the power wire, whatever it takes to turn the amp off. I don't suggest you do this because you have a completely different problem.
Old 05-22-2013 | 08:55 PM
abirvalg's Avatar
that has to be wiring picking up RF
i had a similar issue with passive crossovers
move wires and components (other than the speakers) around
BoricuaTL
04-08-2016 01:08 PM
handsom-hustla
11-13-2015 05:04 PM
mgbe11
1/2G MDX (2001-2013)
09-15-2015 07:53 PM
Pegon95
09-15-2015 01:54 PM
vanderveen44
ILX
09-02-2015 01:48 PM
Quick Reply: Static on radio after amp installed?
