Speaker grills
Speaker grills
hi guys.
im changing my front and center speakers so I have these qs...
im using a MB quart 6.5 set with amps and the 3sixty....
1- the tw and center sp grills just pop up for changing em???
2- have been reading about the 6.5 , and see that they need some modification to fit on the original space, what kinda mod???
3- what center speaker would you recommend me to upgrade??
thanks you all wise guys!!!
Coolest A-zine Member
hi guys.
Yes
Are you talking about 6.5" for doors or Center? If it's for the center, I honestly wouldn't worry about it. The center isn't used hardly at all...
See above
Yes
See above
chopperdude (12-21-2011)
Jokerman
i know when i put my 6 1/2" components in th front, they didnt fit properly. I did all the research and 6 1/2 inch was the right size, but our cars have a special 6 1/2 inch. I just decided to cut out the sheet metal on the door in order to get them to fit. I had to use the peaker grille ring in order to bring the speker up a little away from the sheet metal so that the magnet wouldnt interfere with the door internals.
kb1rl
09-30-2015 10:17 AM
polish_pat
09-25-2015 12:24 PM
