Siemens SX66, MDA III, Blue Angel, XDA IIs
I have been looking on the web for a long time to find out if this pha/phone works with the TL. I can't believe that noone has tried it yet! It was released weeks ago in Europe but is GSM and people have been using it in the USA successfully. Can be purchased from Expansys, and soon will be offered by AT&T and Cingular.
Do we finally have a PDA/phone that works well???
Moderator Alumnus
Can we say Blackberry 7100t is PDA phone? If so, someone seems to use it now.
https://acurazine.com/forums/showthread.php?t=89299
well i tried my pka2k, so here is teh deal. it does pair but you cant use the stearing wheel to make and recieve calls. i have transfer the call frm my pda. at least my nokia works fine.
Could you check if using the patch that people talk about below helps?
http://www.expansys.com.au/forumthre...E_III&thread=3
well it seems i have to do some searching around to find the patch so i will try it later and let you know. it does pair and you can transfer the call so im assuming there will be a patch sooner or later.
3rd Gear
well it seems reciveing calls thorugh the car DOES work. so teh only thin you cant do is dial out from the stearing wheel. ill see if there is an update and report my findings.
update: there is nothing on that club imate site or forum.
3rd Gear
http://www.clubimate.com/index.asp?P...VICE_PDA2K_UPD
Will it fix the Bluetooth issues? It doesn't say.
Here are the information provided about this new ROM:
Rom version 1.12.22 WWE (10/24/04)
Radio version 1.02.00
ExtROM version 1.12.22 WWE (English)
ExtROM version 1.12.22 (Arabic)
English Fixes: Improves radio performance and stability.
Arabic Fixes: Improves radio performance and stability. Displays Arabic text on more websites.
the rom update does not fix the issue. when the device is off the BT is in hibernation so you need to turn the pocket pc on so the BT is "awake" then it will automatically recognize it. another serious problem is that the phone turns on automatically when connected to the car. thsi should be fixed when they get around to releasing a patch. BT headsets have the same issue as well. this device has many BT issues.
CLOSED: 3G Acura TL Model Car(Blue)
bluetl04
08-16-2016 02:49 PM
detailersdomain
Wash & Wax
10-09-2015 10:13 PM
