Im surprised this post is not getting more attention than this... you guys know that if it works we would be able to play music and keep the full phone integration.
Im hesitant to buy one for 150$ just to try... i was going to try it using my brothers 4G but someone said the module is behind the audio consol? Which would make it a bigger job than my bro would allow....
I doubt it's that simple of an swap. Be a guinea pig for us, try it, and you can be forever engrained within the realms of Acurazine history as the guy who added OEM integration of music to the 3G TL!
now that i recall my cousin has a 4g... If someone can confirm where the module is on the 4g ill ask my cousin see if he's up to let me take his car apart lol
just start taking the dash apart until you find something that looks like it and has the same connector!
if 04-06 connector wiring is different than 07-08 module then I would say 98% chance its not directly plug and play. On a bright side if you could get it to work then Bluetooth Audio streaming is now build in
He has a 07/08 so he found out the connector is the same as the 4G.
OP best bet is to find a use one from a junkyard or make the attempt and remove the one from your brother's TL. Don't go by what someone said, find out exactly. GL
What he said! If you can get it to work, I'd buy you some beer!
I am so tempted to this but its one expensive trial.
How about you guys chip-in, and if everything works out, i'll refund you all, otherwise i'll try to return it and if that works i'll refund you as well?
I found one for ~100$ on ebay shipped.
If 3-4 of you send me 10-20$ each, i'll pay for half of the cost?
